Home > Technical (L322) > Activating Engineering Mode - 11MY onwards (includes L405)
fairwx
2015 Range Rover Vogue SE SDV6 Luxor
Some might find this useful, use at your own risk. (Works with all vehicles that have the TFT instrument display if you are unfamiliar with model year of software details)
To place your vehicle in Engineering Mode if you have GEN 1.5 and 2.0 Software -
Press the "i" button and start button for 3-5 seconds.
The centre TFT display will show that the car is in engineering mode and will allow you to scroll through a number of screens to view different settings, fault codes, specifications and software information as well as a number of self tests, voltage information for key systems and status of a number of chassis and MOST components.
Hold "i" to exit.
You can't amend settings or clear any fault information, but you can view it.
I found this out by accident, being too quick on changing my trip computer before I'd switched the engine on!
Post #228168 10th Dec 2013 10:21pm
Is this similar to the 753 "hack"? 2008 MY Supercharged
Post #228225 11th Dec 2013 2:27am
how does this work on a 2010 model ? Confused All my spelling errorz are belong to me!
2023 FFRR L460
2020 Range Rover Velar
Post #228241 11th Dec 2013 9:03am
fairwx
yes should work fine on 2010, as it has gen 1.9 software.
Post #228857 13th Dec 2013 12:24pm
B9er
Northern Ireland 2010 Range Rover Autobiography 5.0 SC V8 Java Black
Where is the "I" button? Should've been old enough to know better...doh!
Current 2010 5.0 SC Autobiography
Previous 2006 TD6 Vogue SE
Previous 1998 P38 4.6 Vogue Autobiography 50 (No 10)
Post #228869 13th Dec 2013 12:48pm
jez000
United Kingdom 2011 Range Rover Vogue SE TDV8 Bournville
Think its on the indicator stork, the button that changes the small display from MPG to miles to empty etc .... 2021 P400 Silicon Silver AB
Gone 2011 Bournville TDV8 VSE
Gone 2008 Black Canadian HSE LUX
Post #228891 13th Dec 2013 1:18pm
fairwx
yes, "i" button is on the end of the left hand stalk
Post #229430 15th Dec 2013 11:14pm
Baron
United Kingdom 2011 Range Rover Vogue TDV8 Baltic Blue
Yep, works on my 11MY 4.4 TDV8......not that I understand what it is showing me Rolling Eyes 4.4 TDV8 Vogue Baltic Blue MY11
Post #229451 16th Dec 2013 12:58am
