![]() | Home > Technical (L322) > Glow plug test ? |
| fairwx Member Since: 10 Nov 2011 Location: bristol Posts: 124
maybe wire it up to a 12v bat for few seconds to see if it glows..
| Katash Member Since: 10 Apr 2011 Location: Hereford Posts: 700
you can check the resistance with a multimeter - cant remember correct range but its very low - something like 0.4 - 0.9 ohms. |
| dingg1 Member Since: 29 Jun 2013 Location: PORTUGAL Posts: 1420
| nicedayforit Member Since: 11 Jun 2011 Location: Beside the Solway Posts: 3989
As above, the easiest way is to connect it to a battery and see if it glows, should be almost instantaneous.
And either pulse it or take it off after 1 second or it may burn out. |
| Steverr Member Since: 27 Oct 2013 Location: Bristol Posts: 191
| All times are GMT |
