Home > Technical (L322) > Glow plug test ?
Steverr
United Kingdom 2003 Range Rover Vogue Td6 Zermatt Silver
Glow plug test ?
How do I test the glow plug on the fbh. I've taken it out and cleaned it up. Need to check the glow plug tho before it goes back in. Can I do it with a multimeter ?
Post #228625 12th Dec 2013 5:36pm
fairwx
2015 Range Rover Vogue SE SDV6 Luxor
maybe wire it up to a 12v bat for few seconds to see if it glows..
might be risky but logically would work..
Post #228661 12th Dec 2013 7:21pm
Katash
England 2007 Range Rover Supercharged 4.2 SC V8 Zermatt Silver
you can check the resistance with a multimeter - cant remember correct range but its very low - something like 0.4 - 0.9 ohms.
Post #228811 13th Dec 2013 9:21am
dingg1
agreed
Post #228816 13th Dec 2013 9:52am
As above, the easiest way is to connect it to a battery and see if it glows, should be almost instantaneous.
Just don't hold it in your fingers while you do it. Thumbs Up Very Happy
Post #228821 13th Dec 2013 10:17am
Katash
And either pulse it or take it off after 1 second or it may burn out.
Post #228870 13th Dec 2013 12:49pm
Steverr
Thumbs Up thanks guys will give it a glow.... Laughing Laughing ha ha get it ,,, did you see what I did !!! Glow .. Go... Rolling with laughter Rolling with laughter
Post #229311 15th Dec 2013 4:38pm
