![]() | Home > Maintenance & Mods (L322) > 2007 Roof Rails/bar???? |
Sandyt Member Since: 07 Nov 2013 Location: Wraysbury Windsor Posts: 2286 ![]() ![]() ![]() |
Hi all have searched and read a large number of posts here and on other forums and I am still unsure if there is a roof rack/rail/bar system that can be fitted and removed without having to cut the 6 channel covers out of the roof any help much appreciated as I dont like the idea of butchering the vehicle |
GraemeC Member Since: 01 Jul 2012 Location: Chester Posts: 836 ![]() ![]() ![]() |
Yes there is, they are called Sports Bars and fit to the front and middle fixing points - just flip the covers up and screw them in, very easy to fit and can be fitted/removed with no permanent modifications to the car.
Brilliant thank you gents I need to go and get some plasterboard now but in the summer have a top box so very infrequent use I have a thule tow ball mount bike carrier but both sound spot on ta |
Alistair Member Since: 11 Feb 2011 Location: Peterborough / Bordeaux / Andorra Posts: 8108 ![]() ![]() ![]() |
The RR fixed bars are (I think) a little wider, so depending on which roof box you have, you may need to make some adjustments. |
Well I was going to suggest to domestic management that she take less away with her but need to do that be phone really |
This system is very good, but does mean snapping off the covers in the roof rails to fit...
Yes I did look at these and thought they looked good its just the fact that the rails have to stay on all the time after snapping the covers off I assume the same is true for the Landrover version which to me is nuts having said that I wonder how many people prefer the rails or no rails ?? |
I've had them on my last two FF's and they were fabulous. The fore & aft rails stay fitted forever and you just take the end cover off, slide in the roofbars |
p38arover Member Since: 16 Dec 2015 Location: Western Sydney Posts: 1583 ![]() ![]() |
A late update for this thread. The Rhino Racks RLCP legs with the M166, M167, M168 feet don't require removing the covers. I have them on mine.
