Home > Maintenance & Mods (L322) > 2007 Roof Rails/bar????
Sandyt
Hi all have searched and read a large number of posts here and on other forums and I am still unsure if there is a roof rack/rail/bar system that can be fitted and removed without having to cut the 6 channel covers out of the roof any help much appreciated as I dont like the idea of butchering the vehicle
Post #229138 14th Dec 2013 5:18pm
What do you want to carry & how often ?
I've got a Thule rack & it works well.
I didn't want the fixed system as I only use it occasionally and I also wanted bars the full width of the car, not just the centre ⅔ of the roof.
Post #229139 14th Dec 2013 5:23pm
GraemeC
United Kingdom 2007 Range Rover Vogue SE TDV8 Zermatt Silver
Yes there is, they are called Sports Bars and fit to the front and middle fixing points - just flip the covers up and screw them in, very easy to fit and can be fitted/removed with no permanent modifications to the car.
Example here - http://www.ebay.co.uk/itm/Range-Rover-L322...2582048e74
You can also use Thule bars which don't utilise any of the fixing points on the vehicle 2007 Zermatt Silver TDV8 Vogue SE - now sold but was a great car!
Post #229140 14th Dec 2013 5:23pm
Sandyt
Brilliant thank you gents I need to go and get some plasterboard now but in the summer have a top box so very infrequent use I have a thule tow ball mount bike carrier but both sound spot on ta
Post #229142 14th Dec 2013 5:27pm
The RR fixed bars are (I think) a little wider, so depending on which roof box you have, you may need to make some adjustments.
Post #229146 14th Dec 2013 5:39pm
Sandyt
Well I was going to suggest to domestic management that she take less away with her but need to do that be phone really Whistle Whistle
Post #229189 14th Dec 2013 10:18pm
This system is very good, but does mean snapping off the covers in the roof rails to fit...
http://www.ebay.co.uk/itm/Roof-bar-kit-for...27da6ff743
Post #229205 14th Dec 2013 11:00pm
Sandyt
Yes I did look at these and thought they looked good its just the fact that the rails have to stay on all the time after snapping the covers off I assume the same is true for the Landrover version which to me is nuts having said that I wonder how many people prefer the rails or no rails ??
Post #229208 14th Dec 2013 11:06pm
I've had them on my last two FF's and they were fabulous. The fore & aft rails stay fitted forever and you just take the end cover off, slide in the roofbars Thumbs Up
There many fitting points made the sliding bars very flexible Thumbs Up
Post #229214 14th Dec 2013 11:19pm
p38arover
Australia
A late update for this thread. The Rhino Racks RLCP legs with the M166, M167, M168 feet don't require removing the covers. I have them on mine.
http://vpm.cdn.rhinorack.com.au/Instructio...RLCP05.pdf Ron B. VK2OTC
2003 L322 V8 Auto
2007 Yamaha XJR1300
Post #380021 30th Mar 2016 5:21am
