Home > Maintenance & Mods (L322) > MY07 Key fob
sleepezy
MY07 Key fob
My key fob seems to have started to play up - it won't lock/unlock the car occasionally. I've done my duty and searched the forum/internet but it doesn't seem to be the usual suspect of radio interference as the problem arises almost anywhere, even at home where it's been fine for the last couple of years (ie since we moved in!)
I think it may be the rechargeable battery on it's last legs (version that's charged by induction) as it can't unlock/lock more than twice without failing. I've tried going for a long drive to charge it up (2 hrs yesterday) but it failed to lock again today.
Has anyone else come across this? If so, is there an easy (read:cheap) fix or is it new fob time???
Cheers
Post #229539 16th Dec 2013 2:49pm
how does the spare key perform? ... - .- -.
Post #229542 16th Dec 2013 2:50pm
sleepezy
If I had one I could let you know!
(Should have said, sorry)
Thanks
Post #229587 16th Dec 2013 5:22pm
could be the battery , six years of use has worn it out probably.. ... - .- -.
Post #229589 16th Dec 2013 5:30pm
sleepezy
Thanks Stan - that was what I feared as from searching about it looks like a new key is needed Sad - I am so hopeless at DIY with these things I would destroy the key completely if I tried to replace the rechargeable battery
Post #229597 16th Dec 2013 6:02pm
have words with member daveo, he's an expert on keys.. ... - .- -.
Post #229613 16th Dec 2013 7:26pm
tobylo
Ireland 2008 Range Rover Vogue SE TDV8 Stornoway Grey
probably the battery they won't last forever, i bought a new key cover on ebay and changed the battery as they key i got on my RR was well worn, it had done 152k in 4 years, so a lot of opening and closing i guess. Anyways i took the old pcb out and swapped it over, put in new battery and changed the key, then glued it all back and it works a treat and charges. Works much better and the range seems better as well. I have another cover i'll be listing on the parts for sale in the next few days.
Post #230805 22nd Dec 2013 3:59pm
