Home > Technical (L322) > Big Engine Problem |
Sandyt Member Since: 07 Nov 2013 Location: Wraysbury Windsor Posts: 2230 |
Excellent at least it is moving forward keep us informed. |
16th Dec 2013 6:14pm |
johnboyairey Member Since: 11 Jan 2013 Location: surrey Posts: 2032 |
guessing here, if you found where the injector harness gets back to the ecu pulse area, if you disconnect that multiplug then your injector wires would then show disconnected, ie on others, if you are still seeing an earth say, you could have an injector harness wire trapped under an component, or nut etc, causing this earth you may be now seeing, (on no1) possibly from your PCV removal etc.... and this may help you test it out the 8 cylinder harness without spiking the ecu with a simple volt/ohm meter... good luck. |
16th Dec 2013 6:47pm |
FTS999 Member Since: 18 Jul 2013 Location: Wiltshire Posts: 37 |
I carried out some testing on the wiring for injector number 1 today. My diagram shows a red & white wire that carries the permanent live to the injector and a brown and white carries the earth signal from pin 41 of the ECM.
17th Dec 2013 4:42pm |
I have found out the live is permanent which means the signal is via the earth. If this is correct this must be controlled by the ECM. Does anyone know what the pin number is for injector number 1 signal wire? |
17th Dec 2013 6:38pm |
indeed according to the RR circuit diagram, the colours are red/white and brown/white, (inj no1) going back to pin 41 on the ECM. are you sure you are on the ECM.. I don't know off hand what is the ECM without opening up the blackbox etc. maybe post a pic of the unit and you pointing to pin 41 etc. someone here will know, |
17th Dec 2013 10:03pm |
I have carried out further wiring tests today and there is only 0.03v from the ECM to the faulty injector. Here lies the fault, no output from ECM. |
18th Dec 2013 2:36pm |
i assume you have tested a working injectors pulse? to compare etc. |
18th Dec 2013 4:01pm |
Contraband Member Since: 08 Nov 2010 Location: FIFE Posts: 3697 |
It could be being pulled down to 0.03v.. Have you checked for o/c or s/c on the wiring from that pins connector to the injector?
18th Dec 2013 4:18pm |
I have tested the perminant live feed to the injector plug and that is fine around 13.5v.
18th Dec 2013 7:47pm |
How are you getting on with this? Previously..
20th Dec 2013 6:50pm |
I have the ECU out now but finding someone to test it is proving difficult. Saying that I have just found a company in Bournemouth that might be able to help. |
20th Dec 2013 7:13pm |
mmm, i see you are getting 13v from perm feed wire, and it goes through injector and back to pin41 i assume that the aforementioned 13v is returning to pin 41 via in circuit injector. (if you earth this returning wire it will operate injector yes?) this pin connection (pin41 on ECM) will of course be dragged down by the load of the injector no? when in circuit, are you calling this closed cicuit voltage 0.3v? the pin 41 might not have a voltage as it is switching internally, and 'absorbing the voltage' from the injector circuit. have you compared a working injector pin condition to your suspect no1 inj'. I dont want to pour doubt on your testing, but i still think it will smoke to hell even when you get this injector to fire. i hope that testing this ecu wont break the bank. is it not possible to briefly test it in a differenrt car? i dont know if this part is coded to the security etc. -if it is, be very carefull NOT to lock the car with it removed, as you will lose snch. and on a P38 that means you need another gadjet to resynch etc.
20th Dec 2013 9:07pm |
lastly, in my old v8 p38 days, i used to sometimes ring up RPI in norfolk, was known as v8engines.com they are the experts on the rover v8, but must have hand in the BMW engined cars by now. there are a couple of guys that will talk to you (for free) but they do seem to bombard you with thinking questions, and suggestions, so have a pen ready.
20th Dec 2013 9:12pm |
THanks for your comments. It's sometimes hard to wright down exactly what testing has been done, and for the third party to understand exactly.So I will try and get it all across word perfect.
21st Dec 2013 11:55am |
