Home > Technical (L322) > engine system fault/ terrain function prob advice please.
goldsax
United Kingdom 2011 Range Rover Vogue 4.4 V8 Ipanema Sand
battery/alternator all ok.
while driving today:
engine system fault+ terrain function unavailable messages came on.
the car started to slow down (was traveling at 70) and the throttle when pressed revved the engine but would not accelarate the car.
stopped at a lay by. and pressed the throttle ..felt as if in limp mode. revs went up but car hardly moved .
restarted the engine....and the car drives ok, but 10-15% down on acceleration and producing loads of black smoke on the slightest touch of the throttle.
and also the fuel consumption was huge. i could see the needle going down in 15 miles!
1) ERG?
2) pipe works?
3) lambda sensors?
plugged in my ebay OBD reader ( not the super special one Sad as on this forum ) and no codes are showing.
taking it to dealers tomorrow( they are good ) but always better to have a direction /diagnosis so can be prepared.
any suggestions please.
thanks 2011 4.4 TdV8 Nara Bronze
Post #231621 27th Dec 2013 5:31pm
Googsy
Split turbo hose? Present :2008 TDV8 HSE
Gone Audi A5 2.7TDI
Gone Discovery 3 HSE
Gone Mercedes CLK
Gone Range Rover 2.5 DSE
Post #231635 27th Dec 2013 8:02pm
goldsax
thanks for the reply..
turbo hoses...
are these the two hoses, sitting on top/front of the engine bay?
if so, just checked them, and look ok. 2011 4.4 TdV8 Nara Bronze
Post #231640 27th Dec 2013 8:11pm
Googsy
Yes and symptoms you describe are similar to one being split so worth checking Check to ensure clips are tight at both ends. To test you probably need daylight and someone to press accelerator as splits can be hard to spot Thumbs Up Present :2008 TDV8 HSE
Gone Audi A5 2.7TDI
Gone Mercedes CLK
Post #231652 27th Dec 2013 9:43pm
DMRR
South Africa 2009 Range Rover Westminster TDV8 Stornoway Grey
Split hose Whistle Land Rover Addict
XXXXXXXXXXXXXXXXXXXXXXX
Previous
XXXXXXXXXXXXXXXX
2009 5.0V8SC Autobiography
2006 4.2V8SC Autobiography
2004 4.4V8 Vogue
Post #231657 27th Dec 2013 11:06pm
goldsax
LOVE YOU GUYS.. Thumbs Up
man hugs all round
passenger side hose split.
felt a stream of high pressure air escape from the hose when idle and accelerator pressed to 3000rpm. 2011 4.4 TdV8 Nara Bronze
Post #231688 28th Dec 2013 9:30am
Googsy
Gone Audi A5 2.7TDI
Gone Mercedes CLK
Post #231747 28th Dec 2013 5:10pm
