Home > Maintenance & Mods (L322) > rear suspension arms
andyleeds
United Kingdom 2005 Range Rover Vogue Td6 Zambezi Silver
hey everyone,
does anyone know how much it costs to replace the rear suspension arms as i have a small amount of play in the pin / bush or is it just a case of replacing the pins & bushes?
andy
Post #233389 7th Jan 2014 1:27pm
Which "pin" / bush? Outer / Inner / Upper / Lower ?
Both the upper and lower outer bushes can be replaced in situ on the car (see wiki for howtos), the inner bushes require a bit more surgery and application (also see wiki!) You will need a decent pressing tool.
Once replaced you may need a four wheel alignment too.
Bushes @ £10 - £20 each depending on which.... then you will most likely want new washers and bolts (add a few more quid) .
Post #233428 7th Jan 2014 3:32pm
andyleeds
cheers joe, i don't know really but was thinking of getting it done at an inde there's a good bmw one near me so i was wondering if i could use them as they owned RR at the time so the components will be theirs...
Post #233545 8th Jan 2014 11:52am
