Which "pin" / bush? Outer / Inner / Upper / Lower ?
Both the upper and lower outer bushes can be replaced in situ on the car (see wiki for howtos), the inner bushes require a bit more surgery and application (also see wiki!) You will need a decent pressing tool.
Once replaced you may need a four wheel alignment too.
Bushes @ £10 - £20 each depending on which.... then you will most likely want new washers and bolts (add a few more quid) .
Experience is the only genuine knowledge, but as time passes, I have forgotten more than I can remember
