![]() | Home > Technical (L322) > trailer lights |
| dave.s Member Since: 01 Nov 2011 Location: Isle of Wight Posts: 127
Have had the check trailer light message come up,but
certainly look clean and dry but will have another look
| Contraband Member Since: 08 Nov 2010 Location: FIFE Posts: 3700
Maybe also have a check in the boot for any signs of water or damp where the trailer socket connects to the main loom. Previously..
Ok thanks, will have a look in the morning. Hopefully
Hi all,trailer light fault still showing plus car now has suspension locked out
| stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35885
simplest way would be to follow the wiring from the outside socket and then un-plug the plug.. ... - .- -.
Cheers Stan, looking at fitting instructions i assume i can just
it wont cause any other problems but it will help to see if its the cause of your existing one.. ... - .- -.
Cheers Stan, been out today and as per usual for the
great thing about the FF is that it does sometimes fix it self. |
It won't be a sticky pin sir as the male/female connectors just slide over each other... You can just unplug the ECU in the right side of the boot and it will deaden the system... I would guess the ECU has a problem... As stated above, check there is not a leak in that side of the boot. And, the spare wheel is secure (as the trailer wiring runs across the back panel) and could be squashed or chaffed if the spare is not secured...
Cheers C.T.C, have unplugged loom so hopefully
Your welcome |
| All times are GMT |
