![]() | Home > In Car Electronics (L322) > Bizarre radio gremlin |
| stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35876
seems likely.. |
| crookedm Member Since: 23 Sep 2012 Location: Heswall Posts: 698
Man of many words. Next! |
| PaulB Member Since: 17 Jul 2011 Location: Hampton Posts: 877
Search |
| Mustard Member Since: 25 Jun 2013 Location: North of South Posts: 299
Check around your bluetooth module as this usually soaks up the water first,
I did search which is why I put the last part of the post. |
Thank you! Oh no it's freezing tonight! That's my Sunday morning sorted then! |
Its a real pain in the |
It is a common problem.
Appears to be an egg cup worth of water in the spare wheel well. Cleaned up, no corrosion or damage to any electrics. I can see at the corner of the left hand seal at the bottom it's not as flush as the other side. I will order a new seal. May check warranty to! Although as the name of the day ends in 'y' it's probably a no. |
You still need to find where its coming from, if its coming in at the bottom of the seal I doubt this would affect the electrics panel on the side. Pop the D pillar internal plastic trims off and see if the wadding on the back is wet, also put something like a swing bin liner around your electrics and then pack in some pieces of kitchen towel or bits newspaper pages on the top of it all and leave it for a couple of days, check back for any evidence of water showing up, may take a few good showers to do it though..... |
Ahhh |
Its raining hard out there, you leaking ? |
| All times are GMT |
