Home > In Car Electronics (L322) > Bizarre radio gremlin
crookedm
2007 Range Rover Vogue SE TDV8 Java Black
I have a 2007 3.6 TDV8
Driving along happily with the radio on. When suddenly the sound went off and the orange power button started to flash. I couldn't turn it on or off. The DVD and cd also greyed out.
Eventually the press power button menu screen came on and I was able to listen to the radio and go between aux etc.
Utterly weird. One point though the left hand side of the interior of the boot does seem slightly wet so I'm wondering if I have water ingress somewhere that's causing electric issues?
Post #234141 11th Jan 2014 8:10pm
seems likely..
Post #234160 11th Jan 2014 9:01pm
crookedm
Man of many words. Next! Rolling with laughter
Post #234168 11th Jan 2014 9:12pm
PaulB
2017 Range Rover Autobiography SDV8 Loire Blue
Search Laughing
Post #234177 11th Jan 2014 9:52pm
Mustard
Check around your bluetooth module as this usually soaks up the water first,
Take your spare wheel out and see if you have any water collected in the wheel well,
Do not forget to check the other side of the boot as theres a panel of relays etc over there too, dont want them wet !!
We have had a ton of rain fall on us these past few days so I would put a small wager on it that water ingress is your problem here, water inside your motor and freezing weather approaching aint good matey Mad
Post #234179 11th Jan 2014 9:55pm
crookedm
I did search which is why I put the last part of the post.
Post #234183 11th Jan 2014 9:57pm
crookedm
Thank you! Oh no it's freezing tonight! That's my Sunday morning sorted then!
Post #234185 11th Jan 2014 9:59pm
Mustard
Its a real pain in the Censored but you must get the water ingress sorted out asap. Mines bone dry these days but it took a fair bit of elbow grease & pound notes to get it that way. Have a decent breakfast and get stuck in to see if your suffering another god dam land rover common fault Censored
Post #234193 11th Jan 2014 10:38pm
PaulB
It is a common problem.
Land Rover will even sell you a 'water shedder' to divert the water!
Post #234194 11th Jan 2014 10:41pm
Mustard
Rolling with laughter Rolling with laughter
Post #234196 11th Jan 2014 10:44pm
PaulB
http://www.fullfatrr.com/forum/topic4551.h...er+shedder
Banging Head
Post #234200 11th Jan 2014 11:25pm
crookedm
Appears to be an egg cup worth of water in the spare wheel well. Cleaned up, no corrosion or damage to any electrics. I can see at the corner of the left hand seal at the bottom it's not as flush as the other side. I will order a new seal. May check warranty to! Although as the name of the day ends in 'y' it's probably a no.
Post #234251 12th Jan 2014 11:10am
Mustard
You still need to find where its coming from, if its coming in at the bottom of the seal I doubt this would affect the electrics panel on the side. Pop the D pillar internal plastic trims off and see if the wadding on the back is wet, also put something like a swing bin liner around your electrics and then pack in some pieces of kitchen towel or bits newspaper pages on the top of it all and leave it for a couple of days, check back for any evidence of water showing up, may take a few good showers to do it though.....
Post #234363 12th Jan 2014 8:26pm
crookedm
Ahhh Censored ! Back out at the weekend!
Post #234992 14th Jan 2014 10:28pm
Mustard
Its raining hard out there, you leaking ?
Post #234994 14th Jan 2014 10:31pm
