Home > Maintenance & Mods (L322) > Stuck can't open vehicle
Page 2 of 3 <123>
kiter
I had this problem - battery was dead. Bought a new battery as old one wouldnt charge, prised off one of the side indicator repeaters on the wing, disconnect it - expose a short length of the live feed, attach a wire between this and the live on the battery, earth it and after about 20 - 30 seconds there was enough juice to open the door. Full write up is on rangerovers.net I really didnt think it would work but it did and I'm not that technically minded (if I can do it anyone can). Just re insualted the exposed wire and popped the side repeater back in. I now have a towbar and electrics so just have a spare plug that I can connect to a battery if it happens again.
Good luck
S
Post #234704 14th Jan 2014 9:17am
rej
England 2006 Range Rover Vogue 4.4 V8 Zambezi Silver
Well the AA turned up after about 90 mins and as I went outside I pressed one of the remotes, hey presto lights flash and doors unlock. Repeated locking, unlocking (with drivers door open) several times and no problem. Car started first turn of the key, battery checked and said to have a full charge. Locked at home last night, unlocked this morning plus several tests and all ok so I guess a random fault or some kind of interference.
As I only bought the car on Friday from a dealer I have told him about the problem with the manual lock so that he can fix and also look at the rear camera which only works when it wants to.
If the dealer is not interested in the lock any idea where to start looking for a fix or do I have to buy a new unit from Land Rover? There is a difference between knowing your sh!t and knowing you're sh!t
2005 Registered 2006 MY 4.4 AJV8 Range Rover Vogue
Post #234743 14th Jan 2014 11:52am
Sounds as if you need to take a large Faraday cage with you next time you visit that location.... .
Post #234745 14th Jan 2014 11:57am
Robert, the door lock is a common problem on the FF , you can find out how to fix it via the forums search function..
Post #234749 14th Jan 2014 12:05pm
rej
Is this the fix that I need?
DO NOT TAKE THE DOOR CARD OFF, do not touch the door card, there is no need to remove it, only remove the outer handle and lock and reset the cam to the central position.
Open the door and look at the back, there is a grommet, remove this and it gives access to a torx bolt, remove the Torx bolt and the handle comes off. The lock assembly then lifts out and you have to realign the part that's left inside the door. Just use a screwdriver to do this and reassemble.
When you look inside you will see a slot similar to the either image 1. 2. or 3.
below, the slot could be in various positions depending on how it popped
Using a straight blade screwdriver gently reposition the slot until it is like the image below
Carefully refit the handle, Torx bolt and grommet and test to ensure it is working There is a difference between knowing your sh!t and knowing you're sh!t
Post #234753 14th Jan 2014 12:25pm
if you put the key in the door lock , turned it and the door didnt open then the cable running from the outside lock to the inner mechanism is broken, this means a door card off and the cable replaced...
i gather the inside door release handle works then that cable is ok...
Post #234755 14th Jan 2014 12:41pm
rej
I can open the door using either the internal or external handles. The problem I have seems to be with the lock (key in the door) that does not do anything when the key is twisted in either direction. The car does lock using the remote or the button on the dash, just don't want to be left with no manual ability to open to the car if the remote plays up again.
Robert There is a difference between knowing your sh!t and knowing you're sh!t
Post #234756 14th Jan 2014 12:45pm
understood , then its the actual key lock which needs sorting as per the instructions you posted...
Post #234758 14th Jan 2014 12:49pm
rej
Thanks, I will try tonight if I don't hear anything back from the dealer. There is a difference between knowing your sh!t and knowing you're sh!t
Post #234759 14th Jan 2014 12:50pm
rej
OK lock removed no problem but I could not find the screw shown in the instructions in the door. Photos of what I had out
and what I could see in the door
I could not see the screw to check alignment but just put the lock back in and tightened and it all works. Not sure if just loose. I would ideally like to check the screw's alignment in case of further remote problems if anyone can be more specific where I should be looking. There is a difference between knowing your sh!t and knowing you're sh!t
Post #235050 15th Jan 2014 11:37am
1 out of 10 for your poor photography there Laughing Laughing Laughing
I've tweaked your image, if you look at the area in the yellow box it has a slot that should be in the vertical position before refitting the lock.
As your lock is now working I would expect because of some fluke you managed to align the slot properly. Worth checking with the key once a month or so that it still works properly.
My take on this fault is that the key is only used in emergencies and usually stiff as a result. The owner in a blind panic to enter the vehicle shoves the key in and does not know which way the partially seized lock should turn so starts applying it a bit of muscle and the lock pops out of the slot.
Post #235059 15th Jan 2014 12:20pm
cliffy
2004 Range Rover Vogue 4.4 V8 Zambezi Silver
cheers for this post dude, had the same issue yesterday and had to pump the battery using the starter motor to unlock the car
Post #235068 15th Jan 2014 12:46pm
rej
Thanks for improving the photo, the iPhone flash would either go gown the lock or on the door. I will have another look now I know exactly what I am looking for. There is a difference between knowing your sh!t and knowing you're sh!t
Post #235069 15th Jan 2014 12:48pm
If it's working now you have it aligned properly, no point stripping it down again
Post #235073 15th Jan 2014 12:57pm
cliffy
mines done and working now, i could see where it had been put back peviously that they hadnt alligned it ad it was sitting in the foam liner, works a treat now
thanks again guys
Post #235087 15th Jan 2014 2:10pm
Page 2 of 3 <123>
