Home > Technical (L322) > webasto
Norway
Norway 2003 Range Rover Vogue Td6 Adriatic Blue
webasto
Hi
Where is the webasto actually situated, and how do I get to it.
Vogue 2003 td6
br -03V td6
-72 Cadillac Coupe DeVille 7,7liter.
Post #234829 14th Jan 2014 4:37pm
search 'fbh' or 'fuel burning heater' or have a look in the wiki.... Thumbs Up
Post #234830 14th Jan 2014 4:43pm
Katash
England 2007 Range Rover Supercharged 4.2 SC V8 Zermatt Silver
Front LHS behind wheel arch liner - easy to access, moderately easy to remove and reinstall
Post #234875 14th Jan 2014 8:05pm
Norway
Hi
I still cant get it. What do i have to remove to get
a hand om The Thing.
thx -03V td6
Post #235021 15th Jan 2014 8:22am
jak480
Norway 2003 Range Rover Vogue Td6 Zambezi Silver
The right hand side inner wheel plastic
To reatch the connectors the battery and battery support
What is wrong with it?
Post #235031 15th Jan 2014 9:18am
Norway
The webasto turns on every time I park, but turns off again after 1 minute.
And I dont think its operating while iam driving, since i cant get the engine to keep warm. -03V td6
Post #235043 15th Jan 2014 11:24am
jak480
Looks like a typical webasto ecu problem
When it burns does it smoke a lot?
If You are in the neighborhood of Degernes ( or rudskogen) you could come by I have the tools to read the faults.
Post #235049 15th Jan 2014 11:36am
Norway
Sure, that would be great.
I guess iam driving past you next week.
Iw sent you an pm with contact info.
Not that much smoke, only hot air. -03V td6
Post #235051 15th Jan 2014 11:38am
Norway
Back to the webasto topic.
This never got solved btw.
I now only get cold exaust from the webasto. Why is that? Can it burn cold? -03V td6
Post #464516 14th Jan 2018 11:52am
Dolphinboy
Sounds like it is not firing up. Do you hear the fan start up when you open your door? If so then it is your (pcb?) card - the electronic circuit board. Needs refurb or replacing. Best guy is mike on the Rover 75 site. The contact details are on here somewhere. Search FBH Thumbs Up
Post #464520 14th Jan 2018 12:49pm
Norway
yeah. it fires up. Ill check the pcb -03V td6
Post #464529 14th Jan 2018 3:23pm
Dolphinboy
If it is firing up then The glow plug must be working and it may be too coked up to continue so a de-coke May be in order. These bits of kit do produce a lot of soot apparently.
Post #464568 14th Jan 2018 8:02pm
Norway
Hi Dolphinboy
What do you mean with coked up.
Cheers. -03V td6
Post #464730 16th Jan 2018 6:37am
Dolphinboy
Not an expert on these by any means but the exhaust tube and general burn area gets full of soot after a while and needs cleaning out as it impedes burning of the fuel and causes an early cessation/fault.
Post #464739 16th Jan 2018 9:08am
