![]() | Home > Technical (L322) > webasto |
Norway Member Since: 09 Dec 2012 Location: Høvik Posts: 123 ![]() ![]() ![]() |
Hi
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35801 ![]() ![]() |
search 'fbh' or 'fuel burning heater' or have a look in the wiki.... |
Katash Member Since: 10 Apr 2011 Location: Hereford Posts: 700 ![]() ![]() ![]() |
Front LHS behind wheel arch liner - easy to access, moderately easy to remove and reinstall |
Hi
The webasto turns on every time I park, but turns off again after 1 minute.
jak480 Member Since: 06 Dec 2013 Location: Degernes Posts: 44 ![]() ![]() ![]() |
Looks like a typical webasto ecu problem
Sure, that would be great.
Back to the webasto topic.
Dolphinboy Member Since: 08 Dec 2009 Location: Bristol Posts: 3246 ![]() ![]() ![]() |
Sounds like it is not firing up. Do you hear the fan start up when you open your door? If so then it is your (pcb?) card - the electronic circuit board. Needs refurb or replacing. Best guy is mike on the Rover 75 site. The contact details are on here somewhere. Search FBH |
yeah. it fires up. Ill check the pcb -03V td6
If it is firing up then The glow plug must be working and it may be too coked up to continue so a de-coke May be in order. These bits of kit do produce a lot of soot apparently. |
Hi Dolphinboy
Not an expert on these by any means but the exhaust tube and general burn area gets full of soot after a while and needs cleaning out as it impedes burning of the fuel and causes an early cessation/fault. |
