![]() | Home > In Car Electronics (L322) > Speaker woes |
jambo27 Member Since: 03 Dec 2013 Location: Staffordshire Posts: 125 ![]() ![]() ![]() |
Can you either remove the speaker and wire directly to the amp or run some cable across the back seat directly from amp to in situ speaker. This would tell you if it was the speaker or some wiring issue. |
Paul_H Member Since: 17 Dec 2013 Location: Bracknell Berks Posts: 126 ![]() ![]() ![]() |
I have now fixed the original speakers, and all is well for the moment |
mjdronfield Member Since: 04 Nov 2011 Location: Derbyshire Posts: 7965 ![]() ![]() ![]() |
I'd say that's a good result there then.
The speakers aren't too expensive, it's finding the right ones that is a pain. I've now got a pair of XQM500300's that I thought would fit that will be going back on ebay along with the amp I bought that I didn't need!
Shandonman Member Since: 02 Dec 2013 Location: Argyll Posts: 90 ![]() ![]() ![]() |
This is a job I am going to tackle today. The rear passenger door speakers have never worked since buying the car. After reading this post I am hoping it's something similar as I always thought it an amp fault and not worth the hassle. Did you have to remove the door card to test the speakers ie: access the terminals ? |
goncalo Member Since: 26 Apr 2013 Location: Portugal Posts: 170 ![]() ![]() ![]() |
I have a similar problem... They work but work bad! They make noise and distort the sound.
johnboyairey Member Since: 11 Jan 2013 Location: surrey Posts: 2035 ![]() ![]() ![]() |
this may sound really dumb. but first check that they are not 'faded' out on the display! |
In fact mine are faded out - deliberately, as like goncalo, they make a horrible throbbing sound but only on the LH side. I have had another look and it appears the door card has to come off to get to the wiring. Does yours have DSP goncalo ? |
Yes my have DSP! And is also just in one side as yours!
Took off the door card, tested the speakers - ok. Also checked and cleaned both the black ecu and the silver ecu multiplugs that sit next to the bluetooth module in the boot, I guess one of these is the amp. Still no joy. I wish it had been blown speakers but looks like something more expensive. I have emailed Baris to see whats next. But at least meantime I have unplugged the noisy speakers and I now can fade in the rear to have 10 out of 12 blasting some music. |
I also thought it was blown speakers and i only need to change them! |
Baris has replied asking me to send him the part & he will see what he can do. I have still to find out what & where is the part that he wants but will keep you posted. From what you have said, it does sound like its worth checking your speakers if its a distorted sound you are getting. If I do end up getting the amp/DSP unit repaired I am also going to get the sound upgraded as per mjdronfields posts recently. |
Sorry for the late reply, only just got in from work, I ended up taking the speakers out and testing them.
