Home > In Car Electronics (L322) > Speaker woes
Paul_H
England 2005 Range Rover Vogue Td6 Tonga Green
Speaker woes
The lower rear door speakers are not working in my 06MY RR it has the HK Logic 7 Premium setup, I have done some research and initially thought it was water in the amp (XQK500105), I have been in the boot had the amp out and everything is bone dry no hint of any water ingress. Thumbs Up
Today I changed the amp over for one that was tested to be working and still the lower rear door speakers aren't working so I put the original amp back in and put it all back together Sad
I am a bit OCD with things not working as they should but I don't really no where else to look in the basic diagram in RAVE it shows the bottom speakers feeding off the top but I'm not sure how accurate this is Crying or Very sad
Any help would be greatly appreciated
Paul 2005 Range Rover Vogue with Supercharged Accessories
GONE 2001 Discovery TD5 ES
GONE 1995 Discovery 300 tdi GS
Post #235366 16th Jan 2014 7:11pm
jambo27
Can you either remove the speaker and wire directly to the amp or run some cable across the back seat directly from amp to in situ speaker. This would tell you if it was the speaker or some wiring issue.
Post #235399 16th Jan 2014 9:44pm
Paul_H
I have now fixed the original speakers, and all is well for the moment Whistle
The braid that runs from the terminals to the cone had broken and so there was no current going in, just de-soldered and then re-soldered the braids on both speakers and jobs a good un Thumbs Up 2005 Range Rover Vogue with Supercharged Accessories
Post #238908 2nd Feb 2014 11:59am
mjdronfield
I'd say that's a good result there then.
Don't think the speakers are expensive to replace, it seems finding out what's actually faulty is the hard bit. 2011 Range Rover Vogue SE 4.4 TDV8
Previous cars :
2003 Range Rover Vogue TD6
1999 Discovery Td5 ES
1995 BMW M5 3.8 6 speed
1992 BMW M5 3.8
1988 BMW 735i SE
1989 Ford Sierra XR4x4 2.9i
1981 Ford Fiesta Supersport
Post #238963 2nd Feb 2014 4:07pm
Paul_H
The speakers aren't too expensive, it's finding the right ones that is a pain. I've now got a pair of XQM500300's that I thought would fit that will be going back on ebay along with the amp I bought that I didn't need!
Should have had the brainwave 3 weeks ago would have saved me a few quid Embarassed 2005 Range Rover Vogue with Supercharged Accessories
Post #238980 2nd Feb 2014 5:36pm
Shandonman
United Kingdom 2002 Range Rover Vogue 4.4 V8 Adriatic Blue
This is a job I am going to tackle today. The rear passenger door speakers have never worked since buying the car. After reading this post I am hoping it's something similar as I always thought it an amp fault and not worth the hassle. Did you have to remove the door card to test the speakers ie: access the terminals ?
Post #241882 11th Feb 2014 10:57am
goncalo
Portugal 2007 Range Rover Vogue TDV8 Java Black
I have a similar problem... They work but work bad! They make noise and distort the sound.
I think is the speakers that are faulty! But could be the Amplifier that is faulty? Ex-FULLFATTY now downgraded
L494 RRS P400e Dynamic Narvy Black
-------------------------------------- gone
6 | FF-RR 2007 TDV8 Vogue JAVA BLACK
5 | FF-RR 2003 TD6 Vogue Bonatti grey
4 | Ex-RR 2000 P38 automatic
3 | Ex-RR 1994 300tdi classic
2 | Ex-RR 1993 200tdi
1 | Ex-RR 1991 turboD VM engine
Post #241886 11th Feb 2014 11:19am
johnboyairey
this may sound really dumb. but first check that they are not 'faded' out on the display!
Post #241887 11th Feb 2014 11:21am
Shandonman
In fact mine are faded out - deliberately, as like goncalo, they make a horrible throbbing sound but only on the LH side. I have had another look and it appears the door card has to come off to get to the wiring. Does yours have DSP goncalo ?
Post #241892 11th Feb 2014 11:42am
goncalo
Yes my have DSP! And is also just in one side as yours!
And i think when i change the balance or front rear is also something wrong.
I though it was my speaker that is faulty because it happens more when it is loud and when the musica has strong basses, the speaker make distortion. Ex-FULLFATTY now downgraded
Post #241893 11th Feb 2014 11:48am
Shandonman
Took off the door card, tested the speakers - ok. Also checked and cleaned both the black ecu and the silver ecu multiplugs that sit next to the bluetooth module in the boot, I guess one of these is the amp. Still no joy. I wish it had been blown speakers but looks like something more expensive. I have emailed Baris to see whats next. But at least meantime I have unplugged the noisy speakers and I now can fade in the rear to have 10 out of 12 blasting some music.
Post #241958 11th Feb 2014 4:12pm
goncalo
I also thought it was blown speakers and i only need to change them! Mad
Please keep me informed! I presume we have the same problem! Ex-FULLFATTY now downgraded
Post #241996 11th Feb 2014 6:13pm
Shandonman
Baris has replied asking me to send him the part & he will see what he can do. I have still to find out what & where is the part that he wants but will keep you posted. From what you have said, it does sound like its worth checking your speakers if its a distorted sound you are getting. If I do end up getting the amp/DSP unit repaired I am also going to get the sound upgraded as per mjdronfields posts recently.
Post #242006 11th Feb 2014 7:02pm
Paul_H
Sorry for the late reply, only just got in from work, I ended up taking the speakers out and testing them.
It was a real "lightbulb" moment when I tried it, also my FF is running a Logic7 Premium setup which I initially thought was the amp playing up.
HTH
Post #242039 11th Feb 2014 8:48pm
