Home > Technical (L322) > Rear Heated Seats wiring diagram
Shandonman
United Kingdom 2002 Range Rover Vogue 4.4 V8 Adriatic Blue
Sorry but I can't find wiring diagrams in the RAVE, only descriptions and connector details. Can anyone help, it's for a 2002 ?
Post #235816 19th Jan 2014 11:55am
Here you go
For future ref (and they don't make it easy), you have the workshop manual, the connectors manual and the wiring diagrams manual -> cdlm032n.pdf
[EDiT]
You should be able to actually read this one, the quick upload for the forum resizes images Evil or Very Mad
Post #235822 19th Jan 2014 12:39pm
Shandonman
Hi, thanks for that, so in future is there somewhere I am not seeing on the WIKi that has the wiring diagrams ?
Post #235858 19th Jan 2014 2:31pm
Yes, unless you grab the whole RAVE iso of the net I can't see the circuit diagrams linked to in the wiki.
Here is a link to the wiring diagrams pdf http://ul.to/7myo8nh1
Here is a link to the RAVE download page on here: http://www.fullfatrr.com/forum/topic17363.html?highlight=rave .
Post #235870 19th Jan 2014 3:12pm
Shandonman
Had a wee look at the diagrams & checked all the wiring. You see, ever since I bought the car over 2 years ago, the RH rear heated seat has not worked. The led,s on the switch momentarily light then go out. Swapping the switches made no difference. Anyway today I thought I would have a go & find the fault. After ruling out a few things, using the flash test from Rave gives me three flashes which on the front seats means faulty elements. This is probably correct as using a meter, there is no circuit from any of the three wires on the seat plug. One is earth, another is the other end of the element and the third, a sensor signals back to the switch for more or less power. So at least two of them should have a circuit.
I am unsure if there are more connections within the seat or if it's easily possibly to change the element within. Has anyone done this job previously or opened up one of the rear seats. It's probably a job not worth doing as there is only the occasional brat in the back anyhow but I do like everything to work if it's not too much of a challenge.
Post #235917 19th Jan 2014 6:41pm
Weejock
2002 Range Rover Vogue 4.4 V8 Epsom Green
On the pre-facelift L322 (<2005) the heating elements are stitched into the seat cover, to replace them you need a whole new seat cover.
As you've discovered the light extinguishing after a few seconds indicates an open circuit, as all the elements are in series it only takes one element to fail to render the heating inoperative.
I'm not sure how many elements there are on the rear seats (the front seat has six) but you might be able to disconnect the one (or more) faulty element and jump the connection completing the circuit for the remaining elements to work.
Start by testing each element, each one should be around 0.7-1.0 Ohm, anything outside this indicates a potential fault.
The only element that needs to work correctly is the seat base as the temperature control circuit looks at the heat produced by this element and regulates the heating (it does on the front seats, I assume the rears are the same), if this element doesn't work and is jumped then it could lead to overheating...the elements do burn the seat if damaged so be careful!
Post #235971 19th Jan 2014 10:23pm
