Home > Technical (L322) > Rear Heated Seats wiring diagram |
Joe90 Member Since: 29 Apr 2010 Location: Hampshire Posts: 6399 |
Here you go
19th Jan 2014 12:39pm |
Shandonman Member Since: 02 Dec 2013 Location: Argyll Posts: 90 |
Hi, thanks for that, so in future is there somewhere I am not seeing on the WIKi that has the wiring diagrams ? |
19th Jan 2014 2:31pm |
Yes, unless you grab the whole RAVE iso of the net I can't see the circuit diagrams linked to in the wiki.
19th Jan 2014 3:12pm |
Had a wee look at the diagrams & checked all the wiring. You see, ever since I bought the car over 2 years ago, the RH rear heated seat has not worked. The led,s on the switch momentarily light then go out. Swapping the switches made no difference. Anyway today I thought I would have a go & find the fault. After ruling out a few things, using the flash test from Rave gives me three flashes which on the front seats means faulty elements. This is probably correct as using a meter, there is no circuit from any of the three wires on the seat plug. One is earth, another is the other end of the element and the third, a sensor signals back to the switch for more or less power. So at least two of them should have a circuit.
19th Jan 2014 6:41pm |
Weejock Member Since: 31 Dec 2011 Location: UK Posts: 416 |
On the pre-facelift L322 (<2005) the heating elements are stitched into the seat cover, to replace them you need a whole new seat cover.
19th Jan 2014 10:23pm |
