Home > Maintenance & Mods (L322) > The dreaded battery question..which one.????
greasemonkey1
United Kingdom 2005 Range Rover Vogue Td6 Java Black
hi guys
does anyone know what amperage or what battery should fit a 2005 td6...iv'e phoned numerous sellers on fleabay and all seem to have different opinion on the amperage,the battery in the vehicle at present isn't an original,even though i'm the 2nd owner the battery currently in there looks like it has been replaced at some point ,iv'e also rang euro car parts and gsf and both recommend the BOSCH S5 which carries 110amp,,the existing battery in my td6 states its 92 amp,as the weather seem to be be getting colder late evening / early morning i'm starting to see its taking a little longer to get the td6 turned over,so before the battery fails completely i want to replace the battery,would the 110 amp bosch s5 damage the ecu or is that the right one...if there is a wiki link or if this issue has been covered in the past,please accept my apology and direct me to the link pls...
regards steve
Post #236281 21st Jan 2014 3:06pm
GraemeC
United Kingdom 2007 Range Rover Vogue SE TDV8 Zermatt Silver
Get the BOSCH S5 110amp - loads of people on here have it and, other that it being a tight fit, I've not read of any negative experiences
I love mine - FBH every morning, not a problem Mr. Green
There is no risk of damage to the vehicle ECU's etc. (assuming you follow the disconnection/re-connection procedures)
Battery disconnection procedure can be found here http://www.fullfatrr.com/forum/post67804.html#67804
Battery fitting procedure can be found here http://www.fullfatrr.com/forum/topic16561.html 2007 Zermatt Silver TDV8 Vogue SE - now sold but was a great car!
Post #236283 21st Jan 2014 3:12pm
Vogue
Varta I1 is the battery for a TD6 - I1 is the short code, I understand that they also make them for Bosch
Post #236286 21st Jan 2014 3:25pm
greasemonkey1
thank you both vogue and graeme c Thumbs Up ... the varta i1 carries 110amp too which is a good indication, as the bosch S5 which i was quoted on, also carries 110amp ... iv'e placed a varta i1 on order from fleabay @ £95.00 including next day delivery,happy days.. Very Happy ...thanks again for the clarification guys.. Bow down
regards steve
Post #236294 21st Jan 2014 4:14pm
Do you get the 5 year guarantee with the varta like you do with the Bosch? Previously..
Post #236315 21st Jan 2014 5:49pm
E4 GUY
United Kingdom 2006 Range Rover Supercharged 4.2 SC V8 Java Black
I bought the 110 Varta, delivered for £98
5 year guarantee .
Battery Megastore. Register on their app first , and they give a further discount . Thumbs Up Alcohol and eBay is never a good mix
2006 4.2 Supercharged, Java Black
Post #236331 21st Jan 2014 7:09pm
greasemonkey1
according to the seller you get a 5 year guarantee...heres the link,got the exact battery,here is the link,,copy and paste ..http://www.ebay.co.uk/itm/VARTA-BATTERY-I1-110AH-920A-SILVER-dynamic-610-402-092-/271366430842?pt=UK_CarsParts_Vehicles_CarParts_SM&hash=item3f2eb3207a
Post #236405 22nd Jan 2014 12:59am
