![]() | Home > Technical (L322) > vibration at speed |
| mike & the mechanics Member Since: 08 Sep 2013 Location: Lincolnshire Posts: 178
Have you checked wheel balancing? Mine is on 20" & I had the same took them twice to the place that fitted my tyres to no avail so started to think problem then a TPS valve failed & had to make an emergency call Sturgess landrover at Leicester who re-balanced my wheels & guess what? now perfect. makes you wonder on these big wheels can a lot of independents do them properly!! Worse things happen at sea! Well thats what swmbo said when WRENS came to sea!!! |
Could be a million things from a bush to a buckled wheel to a propshaft unbalance or doughnut issue... There is no common fault I can think of... But many it could be |
| Welshdragon Member Since: 20 Jan 2012 Location: here and there...but not where I should be Posts: 1902
Ok first off then to get wheels checked out, as i'm on 20" wheels as well, but there is no steering wabble at all.
There's a doughnut in the rear prop on the SC in front of me sir... |
Not just looking at it humm... |
Up date - I had the wheels all balanced and swapped the fronts to rears, all seams well at the moment at 50/60 mph |
| northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8788
Simples |
And the one looking for it |
| Googsy Member Since: 02 Jun 2011 Location: Where men are men and sheep are nervous. Posts: 2947
Was gonna suggest not sticking your head out the window when driving but as your sorted it's not relevant now |
| All times are GMT |
