|  | Home > Technical (L322) > vibration at speed |
| mike & the mechanics Member Since: 08 Sep 2013 Location: Lincolnshire Posts: 178      | Have you checked wheel balancing? Mine is on 20" & I had the same took them twice to the place that fitted my tyres to no avail so started to think problem then a TPS valve failed & had to make an emergency call Sturgess landrover at Leicester who re-balanced my wheels & guess what? now perfect. makes you wonder on these big wheels can a lot of independents do them properly!! Worse things happen at sea! Well thats what swmbo said when WRENS came to sea!!! | ||
|  19th Jan 2014 11:53am |
| Cam-Tech-Craig Member Since: 03 Aug 2011 Location: Gloucestershire Posts: 16403      | Could be a million things from a bush to a buckled wheel to a propshaft unbalance or doughnut issue... There is no common fault I can think of... But many it could be  | ||
|  19th Jan 2014 11:55am |
| Welshdragon Member Since: 20 Jan 2012 Location: here and there...but not where I should be Posts: 1902      | Ok first off then to get wheels checked out, as i'm on 20" wheels as well, but there is no steering wabble at all.
|  19th Jan 2014 12:16pm |
| Cam-Tech-Craig Member Since: 03 Aug 2011 Location: Gloucestershire Posts: 16403      | There's a doughnut in the rear prop on the SC in front of me sir...    | ||
|  19th Jan 2014 12:24pm |
|  19th Jan 2014 12:35pm |
| Cam-Tech-Craig Member Since: 03 Aug 2011 Location: Gloucestershire Posts: 16403      | Not just looking at it humm...   | ||
|  19th Jan 2014 12:52pm |
|  19th Jan 2014 1:25pm |
|  19th Jan 2014 1:57pm |
| Welshdragon Member Since: 20 Jan 2012 Location: here and there...but not where I should be Posts: 1902      | Up date - I had the wheels all balanced and swapped the fronts to rears, all seams well at the moment at 50/60 mph   | ||
|  24th Jan 2014 8:24pm |
| northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8790      | Simples  | ||
|  24th Jan 2014 8:30pm |
| Cam-Tech-Craig Member Since: 03 Aug 2011 Location: Gloucestershire Posts: 16403      | And the one looking for it  | ||
|  24th Jan 2014 9:31pm |
|  24th Jan 2014 9:49pm |
| Googsy Member Since: 02 Jun 2011 Location: Where men are men and sheep are nervous. Posts: 2947      | Was gonna suggest not sticking your head out the window when driving but as your sorted it's not relevant now  | ||
|  24th Jan 2014 9:53pm |
|  25th Jan 2014 8:23pm |
| Posting Rules
   r
 r
