Home > Technical (L322) > Auto Lock/Unlock Feature Based on Transmission Position
blueRR2006
United States 2006 Range Rover HSE 4.4 V8 Buckingham Blue
Hello Gap Team,
Hello Gap Team,
I know this has been discussed before, but not with this modification. If it has, I haven't located it searching here. If I missed it, I apologize.
Using the IIDTOOL, can the auto lock/unlock feature be modified based on the position of the transmission selector? In other words, can the unlock feature be activated when moved to the 'P' position and locked when moved to the 'D' position? This feature/option is included with some aftermarket alarm systems.
Thanks
blueRR2006 2006 Range Rover HSE 4.4L Jag Engine/ Buckingham Blue
Post #242117 12th Feb 2014 2:55am
T24RES
No, it wasn't a land rover option. Therefore it won't be on the IID tool, this would require rewriting the software. Same answer for folding the mirrors in when locking the doors. Ian
Post #242118 12th Feb 2014 2:58am
blueRR2006
Big Cry 2006 Range Rover HSE 4.4L Jag Engine/ Buckingham Blue
Post #242122 12th Feb 2014 3:07am
what the IIDtool can and cannot do can be found on the GAP site using the drop down menu,
http://www.gap-diagnostic.com/products/iidtool.html
Post #242135 12th Feb 2014 9:40am
blueRR2006
Hi Stan,
I was just wondering if the IIDTool could be modified with a firmware upgrade or something in the future.
Thanks Thumbs Up
Post #242185 12th Feb 2014 2:00pm
as Ian has said if the option is not there in the first place then it cant be enabled....i very much doubt if each individual ecu can have its firmware re-written and then be able to talk to the other ecus in its daisy chain..
Post #242199 12th Feb 2014 2:50pm
