![]() | Home > Technical (L322) > do you find your heater to hot |
Bellini Member Since: 11 Jan 2012 Location: Berkshire Posts: 2261 ![]() ![]() ![]() |
I run my FF without A/C on most of the time as I don't 'need' the drying effect as 90% of my journeys are long enough to thoroughly warm the engine and interior.
The RR climate control is best run on full auto and I always have both lights on - seems daft not too. I tell all buyers to do the same. |
rej Member Since: 06 Jan 2014 Location: Stevenage Posts: 496 ![]() ![]() ![]() |
I get icy cold air from the centre vents but the car seems warm and I get warm air unless on full blower in the back which makes the centre warm and also where my left knee rests feels warm. There is a difference between knowing your sh!t and knowing you're sh!t
crookedm Member Since: 23 Sep 2012 Location: Heswall Posts: 698 ![]() ![]() |
That means though that your feet get toastie, if I turn mine to auto it blows hot air on my feet, if I then select any of the air direction buttons auto goes off. Am I being a goon? Or should it do that? |
Stan put your IID Tool on and go to live values for climate control and look at the condenser temperature , then hit the max cooling button . If you have gas so to speak the temperature will start to drop .
northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8760 ![]() ![]() ![]() |
Been finding mine was getting too hot on shorter journeys, was fine on a longer run, blew out the internal temp sensor and it was slightly better but still noticed that the temp was was warm for journeys od 10-15min or less. Figured it took a while for the temp sensor to reach a state where it was reading accurate internal temp rather than the ambient temp the car settled at overnight.
@axle, |
