Home > Technical (L322) > Steering Column Tilt Broken
Page 4 of 4 <1234
the_engineer
United Kingdom 2004 Range Rover Autobiography Td6 Buckingham Blue
and i thought i had trouble with mines squeaking.
Didn't realise thats what was driving it. Maybe mines just needs lubed up a little. Is it easy to get it down to the state which i shown in the pictures
Post #111301 6th Mar 2012 9:07pm
Shandonman
United Kingdom 2002 Range Rover Vogue 4.4 V8 Adriatic Blue
Dam, just when everything was going so well
MOT failed today due to floppy steering wheel. Seems to be a common problem with the tilt motor. Looks like a DIY repair is in order & within 10 days
Post #242392 13th Feb 2014 1:45am
I have a motor for sale.... Whistle Discovery 4 HSE
1993 90 Tdi
Post #242443 13th Feb 2014 12:31pm
Shandonman
That could be handy. Does it need a motor. I am going to spend a little time going over all the posts about this as I am not really sure what's involved and I also have the reach thingy not working either (although I can hear the motor running ) so it would be good if I could fix the lot whilst I am in there.
Post #242460 13th Feb 2014 1:48pm
Shandonman
Removed the cowl today to find out what's exactly wrong. Not surprised to see the PO has been in before - the tilt motor was unplugged and I could see why. To be fair he had told me that the tilt didn't work when I bought the car but I see that as per normal, two of the four tabs are broken off and he drilled and tapped a hole & screwed in a bolt to stop the wheel dropping any lower. So I plugged the tilt motor back in and carefully tapped the switch to move the broken casting hard up against the bolt. Then unplugged the motor to avoid the risk of destructing this arrangement. Luckily the wheel is just where I want it. Not ideal but free. As long as it's safe & gets through its retest, I don't see why not.
The reach motor was also working and although it was a pig to access I could see that it had cracked the white plastic moulding that holds it in place and the spindle had popped out as the motor was flopping around. Secured it as best I could with a couple of cable ties.
I am going to keep a look out as mentioned by other posters for a 2nd hand column for the future
Post #242699 14th Feb 2014 7:04pm
Meerbusch
Germany 2017 Range Rover Vogue SDV8 Carpathian Grey
Hi, you need the white plastic part QYH500030, easy to fix with small hand/fingers..., dismount the right dashboard shape, and you can look inside with a lamp. Best wishes, Uli L405 SDV8 2017 + Lancia Flavia Coupe 1964 + L322 TDV8 2011 + RRS L494 3.0 SDV6 + C220CDI Convertible 2021
Post #242924 16th Feb 2014 8:40am
Shandonman
I wonder how much it is for a new piece of white plastic as there is one on eBay for £100 !! Censored
Post #243159 17th Feb 2014 2:57pm
Harris
United Kingdom 2006 Range Rover Vogue TDV8 Zermatt Silver
My column adjusts fine with the lever, and when I take the key out the column goes up but doesn't retract is this normal on an 07? My previous 02 went up and retracted? Or is something broke?
Post #244412 23rd Feb 2014 2:53pm
Page 4 of 4 <1234
