Home > Maintenance & Mods (L322) > Dummy or blank for 12v socket
DeRanged Rover
United Kingdom 2006 Range Rover Vogue SE Td6 Java Black
My son has developed a very annoying habit of pushing in the cigarette lighter every chance he gets. I am quite concerned that he will at some point then also pull it out and end up burning himself or something else ... Is there a dummy plastic plug or something available that I can replace the cigarette lighter with?
I've used the plug for the 12v socket in the cubby to block out the rear lighter but can't find a similar LR one anywhere that I can use for the front ...
May just get this - http://www.ebay.co.uk/itm/GENUINE-VOLVO-12...5404e568c8
Any thoughts? A flush fitting USB type charger thing could also work but not sure if that would end up causing battery drain ? African Bush Junkie ... in London!
Stats:
2006 TD6 Vogue SE
1972-2015 DeRanged Rover
2001 P38 dHSE (SOLD)
Post #243620 19th Feb 2014 2:08pm
Martin
Site Admin
£8 Shocked
Sure Dan will do one, there are a few LR types depending whether it's BMW type (L322) or Ford type (D3) or other (Defender).
Post #243623 19th Feb 2014 2:19pm
DeRanged Rover
All sorted - Dan truly is the Man! Thumbs Up African Bush Junkie ... in London!
Stats:
2006 TD6 Vogue SE
Post #243627 19th Feb 2014 3:15pm
cowman
United Kingdom 2005 Range Rover Vogue SE Td6 Adriatic Blue
you can get a led torch that charges from the lighter socket it is pocket size and would be a useful light in an emergency and completly safe
Post #243674 19th Feb 2014 9:06pm
mjdronfield
Is the torch a land rover one ?
Do you have a link to such an item ?
Had a quick look on the web but they seem a bit big.
Would be nice to have a torch in the car again. Just like my 1988 735 had.....
Thanks 2011 Range Rover Vogue SE 4.4 TDV8
Previous cars :
2003 Range Rover Vogue TD6
1999 Discovery Td5 ES
1995 BMW M5 3.8 6 speed
1992 BMW M5 3.8
1988 BMW 735i SE
1989 Ford Sierra XR4x4 2.9i
1981 Ford Fiesta Supersport
Post #243753 20th Feb 2014 8:21am
cowman
they arent of the net the local motor factors was doing them ,i will get hold of 1 or 2 and see what they are like and get back to you.
Post #243910 20th Feb 2014 9:08pm
cowman
if you go on ebay item number eBay Item No. 151080213289 is the same as i have it is only 2 inches long .
Post #245009 26th Feb 2014 3:54pm
