![]() | Home > Technical (L322) > Engine bay identification of box TDV8 3.6 |
Cam-Tech-Craig Member Since: 04 Aug 2011 Location: Gloucestershire Posts: 16369 ![]() ![]() ![]() |
Tis indeed the air filter box conner |
Thanks Craig am I correct in assuming the two missing screws on inner wing secure this or is it meant to move. I have my MOT tomorrow and they test how secure air filter box is. Like I say mine moves. Thanks. Present :2008 TDV8 HSE
I think they just fit on studs Conner, i can have a look at mine tomorrow if that helps? |
Thanks Craig that would be helpful have test at 11.30 have car A1 so wouldn't like to fail because of it can text you am if that makes it easier as I know your busy |
If you can will even polish the tubes again |
Mine seems to move at the right hand side where it appears to go into the inner wing. Present :2008 TDV8 HSE
Just checked and it floats (as i suspected) on the plastic dowels fitting into the inner wing Conner |
Craig so it is supposed to move? Thanks sir much appreciated |
Yes Conner, supposedly it moves with the engine vibration |
northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8760 ![]() ![]() ![]() |
Conor, did your car used to be light metallic green? Or is that a gallery pic? There is nothing that can't be fixed with a hammer😜😜
