Home > Technical (L322) > Engine bay identification of box TDV8 3.6 |
Googsy Member Since: 02 Jun 2011 Location: Where men are men and sheep are nervous. Posts: 2947 |
19th Feb 2014 10:59pm |
Cam-Tech-Craig Member Since: 04 Aug 2011 Location: Gloucestershire Posts: 16180 |
Tis indeed the air filter box conner |
20th Feb 2014 12:21am |
Thanks Craig am I correct in assuming the two missing screws on inner wing secure this or is it meant to move. I have my MOT tomorrow and they test how secure air filter box is. Like I say mine moves. Thanks. Present :2008 TDV8 HSE
20th Feb 2014 12:33am |
I think they just fit on studs Conner, i can have a look at mine tomorrow if that helps? |
20th Feb 2014 12:35am |
Thanks Craig that would be helpful have test at 11.30 have car A1 so wouldn't like to fail because of it can text you am if that makes it easier as I know your busy Present :2008 TDV8 HSE
20th Feb 2014 12:38am |
If you can will even polish the tubes again cheers. Present :2008 TDV8 HSE
20th Feb 2014 12:39am |
Mine seems to move at the right hand side where it appears to go into the inner wing. Present :2008 TDV8 HSE
20th Feb 2014 12:40am |
Just checked and it floats (as i suspected) on the plastic dowels fitting into the inner wing Conner |
20th Feb 2014 1:10am |
Craig so it is supposed to move? Thanks sir much appreciated Present :2008 TDV8 HSE
20th Feb 2014 1:11am |
Yes Conner, supposedly it moves with the engine vibration |
20th Feb 2014 1:27am |
20th Feb 2014 1:31am |
20th Feb 2014 1:33am |
Conor, did your car used to be light metallic green? Or is that a gallery pic? There is nothing that can't be fixed with a hammer😜😜
20th Feb 2014 8:41am |
no if you look closely at picture it says Farmers Guard thats where I got picture Present :2008 TDV8 HSE
20th Feb 2014 10:56am |
