![]() | Home > Technical (L322) > Rear Screenwashers |
Welshdragon Member Since: 20 Jan 2012 Location: here and there...but not where I should be Posts: 1901 ![]() ![]() ![]() |
A quick search for you Ray found this, hope it helps mate.
@Ray/others. Hopefully not OT or hijacking your thread here.
northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8760 ![]() ![]() ![]() |
The pump is at the front, if it takes a while for the water to arrive it is the non return valve in the top of the tailgate which it scoobied.
mjdronfield Member Since: 04 Nov 2011 Location: Derbyshire Posts: 7965 ![]() ![]() ![]() |
It's a bad design judging by what happens over time. You may be lucky and the valve swap sorts it, but it didn't with mine.
Thanks both. Have seen NRV threads before but when reading this post, it did strike me that I've never heard the pump actually working when pushing the stalk.
