Home > Maintenance & Mods (L322) > Additional Reverse Lights
rej
England 2006 Range Rover Vogue 4.4 V8 Zambezi Silver
Looking for some additional reversing lights and wondered what these might be like. Also can you link into the towbar wiring rather than trying to get wires into the car and associated potential leakage problems:
[url]http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&item=131092671903&fromMakeTrack=true&ssPageName=VIP:watchlink:top:en[url]
or[/url]http://www.ebay.com/itm/Backup-Rear-Reverse-Hitch-Lights-Lighting-Western-Meyer-Plow-For-2-Receiver-/150912546552?pt=Motors_Car_Truck_Parts_Accessories&hash=item232316b6f8&vxp=mtr[url]
[/url] There is a difference between knowing your sh!t and knowing you're sh!t
2005 Registered 2006 MY 4.4 AJV8 Range Rover Vogue
Post #244159 22nd Feb 2014 1:33am
There's no problem getting two 5A cables into the boot area. Just drill two 1mm holes in the large rubber grommet that the tow electrics go thro into the boot and push the 5A cables thro. The holes are tight enough to form a water proof seal.
Drill the holes from inside the boot it's easier. Thumbs Up
You can then run the cables to connect with the reverse light circuit in the rear drivers side compartment and the earth point at the rear of the boot floor.
I wired mine using two relays wired with the contacts in series, one relay switched from the reverse light circuit and one from the side light circuit.
This means in daylight only the original reverse lights come on as normal but when the sidelights are switched on the additional reverse lights also come on.
These are the LED lights I used, purchased from a local motor factor. Mounting brackets are purpose made.
The lights are very effective and produce good rearwards vision even in total darkness.
Handy when there is no street lighting.
Post #244187 22nd Feb 2014 10:32am
paulmoran2
England 2013 Range Rover Vogue SDV8 Mariana Black
Post #244203 22nd Feb 2014 11:28am
mjdronfield
I'd want these deployable like the side steps. Would be cool. Could have loads of lights then, as you'd not normally see them. Prob can't be done.
I did try and fit some cree led bulbs into the existing lights to make them brighter, but did not have any success as the bulbs were too long for the light unit so had to send them back. 2011 Range Rover Vogue SE 4.4 TDV8
Previous cars :
2003 Range Rover Vogue TD6
1999 Discovery Td5 ES
1995 BMW M5 3.8 6 speed
1992 BMW M5 3.8
1988 BMW 735i SE
1989 Ford Sierra XR4x4 2.9i
1981 Ford Fiesta Supersport
Post #244214 22nd Feb 2014 12:31pm
^ There would in fact be room underneath to tip the lights upwards towards the front of the car when not in use if they were mounted on spring loaded stainless steel hinges instead of fixed rigidly like mine.
The lights would then be totally hidden when not in use.
I think a simple bowden cable link into the boot connected to a small 90deg motion wiper motor mounted in the wheel space at the rear of the car would work. Motor energised to drop the lights when switched on.
At a pinch you could mount the motor behind the rear skirt.
You are obviously more descirning than me. Laughing
Something like this,
Post #244241 22nd Feb 2014 3:18pm
mjdronfield
Brilliant. And it stops them getting too dirty.
Why make something simple when you can complicate it...... Laughing 2011 Range Rover Vogue SE 4.4 TDV8
Previous cars :
1992 BMW M5 3.8
1988 BMW 735i SE
Post #244243 22nd Feb 2014 3:32pm
