![]() | Home > Technical (L322) > No HDC and No Change of Transmission Range |
| rej Member Since: 06 Jan 2014 Location: Stevenage Posts: 496
Any idea if this is likely to just be a faulty switch or something more complicated. No obvious error codes when scanned on iid. There is a difference between knowing your sh!t and knowing you're sh!t
| Joe90 Member Since: 29 Apr 2010 Location: Hampshire Posts: 6434
Assume it was all working OK before the panel swap?
New central control panel and HDC and Low Range working again. There is a difference between knowing your sh!t and knowing you're sh!t
| All times are GMT |
