|  | Home > Technical (L322) > YNI500040k - No Longer Available |
| Boat.Buoy Member Since: 10 Jan 2014 Location: Bournemouth Posts: 70    | Ok so I guess it helps to see what you have before you go sourcing parts...turns out I've already got this part fitted, but my interior fan does still run for some time after the ignition is switched off.
|  23rd Feb 2014 7:25pm |
| mjdronfield Member Since: 04 Nov 2011 Location: Derbyshire Posts: 8002      | I'm not exactly sure here, but do you have a flat battery issue caused by the heater fan running when it shouldn't ?
|  23rd Feb 2014 7:30pm |
| Cam-Tech-Craig Member Since: 03 Aug 2011 Location: Gloucestershire Posts: 16403      | Matt, I'm completely lost reading your thread... You might want to give the nice boys & girls on here a little more info as to what you are doing, what the problem is sir  | ||
|  23rd Feb 2014 7:31pm |
|  23rd Feb 2014 7:33pm |
| Cam-Tech-Craig Member Since: 03 Aug 2011 Location: Gloucestershire Posts: 16403      | De ja vue  | ||
|  23rd Feb 2014 7:38pm |
| Boat.Buoy Member Since: 10 Jan 2014 Location: Bournemouth Posts: 70    | Sorry gents...
|  23rd Feb 2014 7:53pm |
| Cam-Tech-Craig Member Since: 03 Aug 2011 Location: Gloucestershire Posts: 16403      | Sounds suspiciously like the HEVAC unit (blower control panel) is playing up... I would try replacing it first...  | ||
|  23rd Feb 2014 7:57pm |
| Boat.Buoy Member Since: 10 Jan 2014 Location: Bournemouth Posts: 70    | Thanks for idea,  I've been trying to source a facelift panel but haven't come across one yet.
|  23rd Feb 2014 8:01pm |
| Boat.Buoy Member Since: 10 Jan 2014 Location: Bournemouth Posts: 70    | Must be my lucky day..just found one on eBay, it'll be with my Wednesday/Thursday so I'll let you know if that solves the problem, if it doesn't at least it'll look nice!? | ||
|  23rd Feb 2014 8:06pm |
| Joe90 Member Since: 29 Apr 2010 Location: Hampshire Posts: 6434    | Where is this "little" fan? Do you mean the one for the interior temperature sensor behind the dash? Does this go off when the car shuts down after @ 10 minutes (red light on gear lever selectortray). Or is it another fan? .
|  23rd Feb 2014 8:32pm |
| nicedayforit Member Since: 11 Jun 2011 Location: Beside the Solway Posts: 3989      | Just curious, how do you know the air temperature sensor fan runs on when the vehicle is asleep?
|  23rd Feb 2014 8:37pm |
| Boat.Buoy Member Since: 10 Jan 2014 Location: Bournemouth Posts: 70    | Thanks for the replies gents,  yes Joe 90 - the one for the interior temp sensor.   I'll measure the time it runs for, but it seems to run for a lot longer than 10 minutes, the red light also stays lit for a long time, I'll measure this too but I guess it should go off at the same time as the fan?
|  23rd Feb 2014 9:07pm |
| nicedayforit Member Since: 11 Jun 2011 Location: Beside the Solway Posts: 3989      | Fuse 27 supplies the BCU which in turn controls all the interior lighting in the car and a good bit besides.
|  23rd Feb 2014 10:07pm |
| 47p2 Member Since: 05 Oct 2010 Location: Gone Beyond, Subaru Posts: 8048    | The 'little red light' takes around 20 minutes to go out | ||
|  24th Feb 2014 8:13am |
| Posting Rules
