![]() | Home > Technical (L322) > YNI500040k - No Longer Available |
Boat.Buoy Member Since: 10 Jan 2014 Location: Bournemouth Posts: 70 ![]() ![]() |
Ok so I guess it helps to see what you have before you go sourcing parts...turns out I've already got this part fitted, but my interior fan does still run for some time after the ignition is switched off.
mjdronfield Member Since: 04 Nov 2011 Location: Derbyshire Posts: 7965 ![]() ![]() ![]() |
I'm not exactly sure here, but do you have a flat battery issue caused by the heater fan running when it shouldn't ?
Cam-Tech-Craig Member Since: 04 Aug 2011 Location: Gloucestershire Posts: 16369 ![]() ![]() ![]() |
Matt, I'm completely lost reading your thread... You might want to give the nice boys & girls on here a little more info as to what you are doing, what the problem is sir |
De ja vue |
Sorry gents...
Sounds suspiciously like the HEVAC unit (blower control panel) is playing up... I would try replacing it first... |
Thanks for idea, I've been trying to source a facelift panel but haven't come across one yet.
Must be my lucky day..just found one on eBay, it'll be with my Wednesday/Thursday so I'll let you know if that solves the problem, if it doesn't at least it'll look nice!? |
Joe90 Member Since: 29 Apr 2010 Location: Hampshire Posts: 6424 ![]() ![]() |
Where is this "little" fan? Do you mean the one for the interior temperature sensor behind the dash? Does this go off when the car shuts down after @ 10 minutes (red light on gear lever selectortray). Or is it another fan? .
Just curious, how do you know the air temperature sensor fan runs on when the vehicle is asleep?
Thanks for the replies gents, yes Joe 90 - the one for the interior temp sensor. I'll measure the time it runs for, but it seems to run for a lot longer than 10 minutes, the red light also stays lit for a long time, I'll measure this too but I guess it should go off at the same time as the fan?
Fuse 27 supplies the BCU which in turn controls all the interior lighting in the car and a good bit besides.
The 'little red light' takes around 20 minutes to go out |
