![]() | Home > Technical (L322) > Charging rate down to 13.8v |
T24RES Member Since: 22 Nov 2010 Location: Henley-on-Thames Posts: 936 ![]() ![]() |
What is going on?
Alistair Member Since: 11 Feb 2011 Location: Peterborough / Bordeaux / Andorra Posts: 8093 ![]() ![]() ![]() |
How old is the alternator ?
New alternator, nothing's been touched since it was fitted. Ian |
I did. That is the voltage with everything off |
That's a nightmare. Maybe the voltage regulator is faulty? Present :2008 TDV8 HSE
Prop Member Since: 26 Sep 2012 Location: Gloucestershire Posts: 675 ![]() ![]() |
I might be wrong, but if your battery has a good charge then 13.8 should be what the alternator/charging system deems as sufficient, it maybe that the alternator will output more when the battery is not as well charged.
nicedayforit Member Since: 11 Jun 2011 Location: Beside the Solway Posts: 3982 ![]() ![]() ![]() |
^+1 The output voltage of the alternator varies depending on electrical load and state of battery charge level.
Cam-Tech-Craig Member Since: 04 Aug 2011 Location: Gloucestershire Posts: 16395 ![]() ![]() ![]() |
Ian, the guys above are quite correct... Finally it would appear the alternator & battery are in sync |
Lets hope so Craig |
drivesafe Member Since: 19 Mar 2008 Location: Gold Coast Posts: 126 ![]() ![]() ![]() |
Hi Ian and when did you actually measure the voltage.
It's been parked since Sunday, first turn of the key and no disco or bongs. Let's hope that's the back of it |
northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8767 ![]() ![]() ![]() |
Sounds promising! There is nothing that can't be fixed with a hammer😜😜
Seems to be regulating itself properly, had a check of the voltage today and peaked at 14.9v before settling down |
