![]() | Home > Technical (L322) > Dead battery this am |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35758 ![]() ![]() |
possibly the FF didnt go completely to sleep because of the door being ajar.. |
funnyguy1 Member Since: 11 Mar 2010 Location: Sun Valley, Idaho Posts: 391 ![]() ![]() |
Thanks Stan, That is exactly what happened. Jump started it and is fine now. I have made a mental note to make sure all doors are completely closed when I shut it down. Mike |
Cam-Tech-Craig Member Since: 04 Aug 2011 Location: Gloucestershire Posts: 16369 ![]() ![]() ![]() |
Mike, the indicators only flash with the alarm set when all the doors are closed sir... Always look for the flash and you know all doors are closed |
Sandyt Member Since: 07 Nov 2013 Location: Wraysbury Windsor Posts: 2281 ![]() ![]() ![]() |
The old p38 used to give a high pitched beep is a door wasn't shut properly odd how things are so called - improved |
exactly! |
one reason why i've activated the lock/unlock chirp on mine with the iidtool, saves me looking at the indicators and i know its locked properly.. |
IIRC you can enable the horn/sounder bits in the CCF on the 2005=> models |
