Home > Maintenance & Mods (L322) > Machine polishing - Help required from the ocd amongst you
T24RES
So i've bought some stuff from a fella................How do i identify the pads? Some are softer than others etc. Should i use any of these polishes? Or what should i buy for the FFRR? Tips on a postcard please Bow down
 Ian
Post #244925 25th Feb 2014 11:31pm
Googsy
Superb have same DA . the megs 105 and 205 are the business next on my buy list.
I think....
Green is heavy cutting pad
Orange medium cut
Yellow polishing pad
Black finishing pad.
With the megs you will only need two pads the orange and the black for finishing. Also I would recommend changing the backing plates that come with the DA and opting for a flexi backing plate. Thumbs Up Present :2008 TDV8 HSE
Gone Audi A5 2.7TDI
Gone Discovery 3 HSE
Gone Mercedes CLK
Gone Range Rover 2.5 DSE
Post #244929 25th Feb 2014 11:45pm
mzplcg
Meguiars polishes are very good. The details about cut levels are on their website.
As for the pads, in all cases you will find the harder the foam then the more it cuts. Hard pads are for serious defects and soft pads are for finishing work. The ones with the pattern on them look to be Hexalogic pads which are very good indeed.
As a rule of thumb you would use the finest polish and the softest pad to start with. Do part of a panel to see the results. Make a decision from there on pad and polish combination depending on how many swirlies you need to get rid of.
3M do some nice flexible backing plates which I use on the Makita rotary machine. That does the bulk of my work but I do also have the G220 for stuff like plastic bumpers and the lower part of L322 doors. I use the standard backing plates with that though but if it's your only tool the flexible plates make life easier.
Post #244941 26th Feb 2014 6:28am
verydisco
Good start! Now => detailingworld.com
http://www.detailingworld.co.uk/forum/foru...c&f=32 l=Oo\________/oO=l l:OolΞΞΞΞΞΞΞloO:l
Current
Previous:
Post #245031 26th Feb 2014 6:25pm
T24RES
I've been on DW a while, lurking, reading and such. Using the group buys when i can Smile
I've seen many 'How To' vids...............
Do you spritz or not? Ian
Post #245034 26th Feb 2014 6:40pm
Rosco
United Kingdom 2013 Range Rover Autobiography SDV8 Baltic Blue
Fair play to you all and I appreciate a detailed car Very Happy When do you get the time, mine is forced kicking and screaming to the polish chaps every 6 months ( £5!)whether it needs it or not Thumbs Up
Post #245037 26th Feb 2014 6:59pm
JAYBOY
Shocked Shocked Brave man 2020 Porsche Panamera Turbo Hybrid (V FAST)
2018 JCW Mini Cooper
2018 Skoda VRS
Post #245050 26th Feb 2014 7:55pm
Mistercorn
United Kingdom 2010 Range Rover Autobiography 4.4 V8 Java Black
Get yourself over to youtube and look up Junkman2000 and watch his videos. Then go to your local car body shop and get a couple of scrap panels to play with. It is pretty easy.
MC
Post #245064 26th Feb 2014 8:26pm
Rosco
Its got to be a a time/age thing. When I first started driving. 30 years ago. my car was immaculate. wash/t-cut etc pretty much everyday. Now with 4 kids, 9 horses, 4 dogs, a bloody cat and land to maintain, if I had a spare hour I would sleep Thumbs Up Thumbs Up
Post #245066 26th Feb 2014 8:37pm
n1cktdv8
I know a little bit, all I would say is never rush it or get dragged into speeding up the polisher if it's a variable...also keep the pads clean and don't let them drag the polish or heat it up.
I use the yellow mostly, but have today polished mine with 3M and finished it with 3M Glaze and a black pad.
Thumbs Up Is this where I put the car details and a bit about myself ?........
Post #245291 27th Feb 2014 3:35pm
T24RES
I'm still reading and watching the vids, awaiting a break in the clouds to coincide with an afternoon off.
I need some more clay n lube, suggestions? I need something more aggressive to remove the black dots on the wheels, the ones you can pick off with your nail. Ian
Post #245294 27th Feb 2014 3:42pm
n1cktdv8
after I tried a few I would suggest Poor Boys Dodo Juice and Clay. Is this where I put the car details and a bit about myself ?........
Post #245299 27th Feb 2014 3:48pm
Googsy
To remove tar Tardis and ironx for wheels for fallout will make the wheels bleed purple Thumbs Up Present :2008 TDV8 HSE
Gone Audi A5 2.7TDI
Gone Mercedes CLK
Post #245329 27th Feb 2014 7:56pm
T24RES
I've got tardis, and sonax wheel cleaner that's similar to iron x. Still left with stubborn little feckers, you can pick them with your nail (if you know what I mean) but it would take forever. I'll try a firmer clay and see how that goes. Ian
Post #245332 27th Feb 2014 8:00pm
Googsy
Try sonax again and agitate with a brush . Present :2008 TDV8 HSE
Gone Audi A5 2.7TDI
Gone Mercedes CLK
Post #245336 27th Feb 2014 8:30pm
