Home > In Car Electronics (L322) > ECU problem
jaipal2004
ECU problem
Hi,
took the car to Jamesons 4x4 in Birm who have the full JLR test book kit etc.
They've not been able to get their kit to talk to my car (L322 2004 4.4v8) - reckon if it takes a day I could be looking at £300'ish to get up and running, but may well be cheaper.
Is there anything else I can investigate myself in the meantime?
Car is giving following:
    Air Susp. inactive
    Sometimes takes >10secs to turn over and fire up
    Possible misfire?
Can't read any of the faults without getting into the ECU's Sad
Cheers
Post #245196 27th Feb 2014 12:26pm
cliffy
2004 Range Rover Vogue 4.4 V8 Zambezi Silver
u could buy ur own diagnostics kit i have the IID Tool on my 2004, also i know the hawkeye worked fine with it and the new snap on tools work a treat to, it might b worth getting another garage to try hooking up to it
Post #245219 27th Feb 2014 1:17pm
+ 1 for the iidtool, but the dealers setup couldn't talk to your FF ,is there a problem with the obd port?
i would also test the battery to make sure its ok..
Post #245224 27th Feb 2014 1:23pm
jaipal2004
Thanks cliffy ... I don't think it's the garage tho' - these guys work full-time on LR's and I've also tried the following:
IID Tool from another kind member on here
AutoLogic (or Autosys) tool from a diagnostics specialist
Surely one of the 3 would've worked - the fact they've all come back with nada seems to suggest the issue is with the vehicle?
Post #245225 27th Feb 2014 1:24pm
jaipal2004
Stan - the battery seems fine to me and I'm sure these guys would've checked that first (after all they're not amateurs).
I did see a mobile Land Rover technician van drive past me in my home town (Darlaston / Wednesbury, West Mids) the other day, tried to get the name or number but was too late Sad
He has suggested the method of disabling/disconnecting all ECU's and trying each one in turn to see which is dragging the network down.
Post #245236 27th Feb 2014 1:45pm
cliffy
well if three aint working its not a 1 off issue
as stan said battery voltage would be my next step
i hav heard it banded around if u disconnect the battery and join the pos & neg together it resets the ecus but dont quote me on this something i have never tried personally
Post #245237 27th Feb 2014 1:45pm
jaipal2004
I've already tried the disconnection of the battery procedure altho' I didn't put the leads together from memory.
The battery voltage is 13.2v when off and 14.3v on idle.
Hope this isn't the start of big repair bills!
Post #245244 27th Feb 2014 2:03pm
batterys good then....it has to be the obd port or the obd fuse gone [if there is one]
Post #245247 27th Feb 2014 2:08pm
jaipal2004
My understanding is that it's essentially a serial network - similar to the old christmas tree lights.... one duff bulb takes out the rest in the circuit
And have looked for obvious signs of it being a fuse and none are blown
Post #245251 27th Feb 2014 2:11pm
i'd get a flashlight and have a good look at the pins in the port..
Post #245253 27th Feb 2014 2:13pm
jaipal2004
stan - do you think it's the port rather than one of the modules??
cheers
Post #245254 27th Feb 2014 2:14pm
could be..
Post #245257 27th Feb 2014 2:15pm
jaipal2004
Will take a flashlight to it and have a look, failing that... a flame and some catalyst Smile
Post #245269 27th Feb 2014 2:42pm
Laughing ..lets hope its something as simple as a bent pin, but you're not out of the woods yet, you still need to sort out your initial problem..
Post #245310 27th Feb 2014 4:29pm
le25dse
Norway 2014 Range Rover Vogue TDV6 Loire Blue
Jaipal,
Did you ever find the solution to this?
I have the same problem, diagnostic tools can't make contact. I have checked the OBDII socket thoroughly and all pins are good. There is also current on all pins in the socket.
I have done all the other things suggested in this thread and still wonder what it could be.
I'm very grateful for ideas of where to check next. ----------
2014 tdv6 (ex. 2004 td6, 1997 2.5 dse)
Post #371662 10th Feb 2016 5:01pm
