![]() | Home > In Car Electronics (L322) > ECU problem |
jaipal2004 Member Since: 13 Dec 2013 Location: Wednesbury, West Midlands Posts: 85 ![]() ![]() ![]() |
Hi,
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35834 ![]() ![]() |
+ 1 for the iidtool, but the dealers setup couldn't talk to your FF ,is there a problem with the obd port?
Thanks cliffy ... I don't think it's the garage tho' - these guys work full-time on LR's and I've also tried the following:
Stan - the battery seems fine to me and I'm sure these guys would've checked that first (after all they're not amateurs).
cliffy Member Since: 17 Apr 2010 Location: Surrey Posts: 556 ![]() ![]() |
well if three aint working its not a 1 off issue
I've already tried the disconnection of the battery procedure altho' I didn't put the leads together from memory.
batterys good then....it has to be the obd port or the obd fuse gone [if there is one] |
My understanding is that it's essentially a serial network - similar to the old christmas tree lights.... one duff bulb takes out the rest in the circuit
i'd get a flashlight and have a good look at the pins in the port.. |
stan - do you think it's the port rather than one of the modules??
could be.. |
Will take a flashlight to it and have a look, failing that... a flame and some catalyst |
le25dse Member Since: 15 Jan 2012 Location: Oslo Posts: 78 ![]() ![]() ![]() |
Jaipal,
