Home > Technical (L322) > Tdv8 gearbox fault
Cossie
Scotland 2008 Range Rover Vogue SE TDV8 Java Black
Tdv8 gearbox fault
Hi I've just become a member but have followed the site for a few years for some good advice. The problem I have is after accelerating quite quickly there was a loud whooshing noise followed by a rotational grinding. I stopped immediately but when ever you engage a gear there is no movement and grinding spins up quickly! It also rolls back in park. There was a burning smell as soon as it happened but went away quickly. Iam bracing myself tomorrow for a gearbox but could it be the transfer box? The noise is from that area. The garage can tell you anything... Also iam better buying secondhand or recon. Any good contacts and advice would be welcome.
Thanks[/b]
Post #245891 2nd Mar 2014 10:11pm
Could easily be the front diff as they are a little problematic... Rarely hear of transfer box issues... Thumbs Up
Post #245912 3rd Mar 2014 12:11am
Cossie
Hi I've been told it's possibly the gearbox and transfer box. Won't no till stripped. Taking it to specialist auto transmission garage . They are looking at 4 k plus vat for recon box and new transfer box.is this a good price...... Landrover asking 8.5k!
Thanks
Post #246316 4th Mar 2014 10:01pm
Easy way to check if you are getting drive from the box and transfer box, do the driveshafts still rotate in drive/creep when the car is going nowhere, if so then front or rear diff problem? There is nothing that can't be fixed with a hammer😜😜
Post #246318 4th Mar 2014 10:15pm
Cossie
Hi when you engage any gear inc reverse the grinding spins up quick and you can see the prop trying to turn from the transfer box but really don't wont to keep doing it for any length of time. The car won't hold in park either.getting a lot of mixed views from mechanics. Problem is it needs stripped to a degree to find out and whoever strips it has got me were they want.ie if I don't go with them I get the motor back with a box of bits and it's not an easy motor to transport about in this state.arrrg.. Would be great if it was a diff but the noise seems to be from the transfer box area as it's trying to turn the prop. No one local will touch it even a couple of landrover specialists.
Post #246331 4th Mar 2014 11:25pm
TugRR
Thought about trying a ZF specialist - I believe they have some depots ?
Thumbs Up Where do you go after one of these . . . ?
Post #246389 5th Mar 2014 9:54am
dhallworth
Mackie Transmissions in Glasgow are ZF specialists.
http://www.mackie-transmission.com/
A friend of mine has used them to do hot flush oil changes on his 2002 4.4 and his 2007 TDV8 and hasn't got a bad word to say about them.
Post #246443 5th Mar 2014 1:29pm
Cossie
Hi that's were it's headed. They have a very good reputation but that comes at a price! Just over half of land rover though. Will keep you posted when I get it back. Thanks for help and advice
Cheers
Post #246532 5th Mar 2014 8:43pm
RRPhil
The big giveaway is that the park lock won’t hold. On the 6HP26X the park lock gear is EB welded to the output shaft :
so, unless the output shaft spline has gone, your fault must lie downstream of the transmission i.e. it’s a transfer box/propshaft/differential/driveshaft problem and not a problem with the transmission itself.
The transfer box is simple to rebuild : http://www.fullfatrr.com/forum/topic12404.html? Alternatively, new ones sell for around £1250 on eBay.
Phil
Post #246539 5th Mar 2014 9:34pm
Cossie
Makes sense basically what I've argued with the first garage. I'am not a mechanic but I no basics of drive train and general mechanics. You have to owning a rangerover!
The situation I'am in is i still have a private warrenty for 2k and until it's stripped I can't get their I dependant guy out. Whoever strips it is going to have to do the job and I'am not not confident with the advice I'am getting. The last thing I need is for someone to strip it, have a box of bits and the evidence of failure gone for the warrenty.
It's going to take the sting out of the tail if they pay out.
But hopefully mackies (we're it's headed) will be honest and change only what's required. Their prognosis was on the phone from the events and symptoms. Not sure how they can be so certain. Just have to wait and see.
Will keep you informed
Cheers 2008 tdv8 vogue SE
2004 td6 vogue
2010 transporter 140
1986 ford cosworth 3door
Dodge ram srt10 gone
Bmw m5 gone
Post #246568 5th Mar 2014 11:16pm
Mackies do know their stuff and have an excellent reputation . 2008 MY Supercharged
Post #246579 6th Mar 2014 12:10am
Cossie
Hi all. Just to keep you updated. Got the rangerover back today from mackies in Glasgow.
Turned out the shaft from the gearbox to transfer box failed causing damage to both units. Mackies were excellent and very helpful. Would really recommend them as they no there stuff.
Pockets are a bit lighter now mind!
Thanks for all the advise and Happy motoring! 2008 tdv8 vogue SE
2004 td6 vogue
Bmw m5 gone
Post #250341 24th Mar 2014 10:36pm
RRPhil
This seems to be the same failure posted by drivesafe (http://www.fullfatrr.com/forum/topic24438.html)?
So are we to believe that this is being caused by the factory failing to coat the spline with the Weicon anti-seize paste before the transmission and transfer box are mated together?
Or possibly the O-ring in the end of the transfer box input shaft is failing to retain the paste/grease? I assume that it’s this grease that is included in the syringe (shown in the top RH corner below) when you buy the input shaft O-ring from Land Rover (IYX 500050).
It would be very interesting to know if other forum members have suffered this same failure – maybe it’s going to become a common issue.
Phil
Post #250410 25th Mar 2014 12:47pm
Cossie
You have a good point here. One word of warning though. There are no tell tail signs the car drove perfect until an almighty bang. Stock up on gearboxes etc and you be sure to sell them soon! My mileage is only 68k. Expected a bit better from such an expensive car new. Land rover are aware of the issue but won't broadcast it.
Finger crossed from now on! 2008 tdv8 vogue SE
2004 td6 vogue
Bmw m5 gone
Post #250523 25th Mar 2014 7:02pm
Or did they not bother uprating this part when they stuck the V8 diesel engine in... is it because it can't take the torque?? Pete
Post #250539 25th Mar 2014 7:53pm
