Home > Maintenance & Mods (L322) > Jacking up with electric side steps
In the owners manual it says you have to remove the electric side step before you jack it up.
I am thinking this might only be the case if you were doing it with the scissor jack as it would probably foul on the steps, but if a garage was doing it with their high lift trolley jacks is it the same?
Can anyone comment?
Seems a right PITA to remove them each time you need to jack it up. Who invented these bloody things? Discovery 4 HSE
Post #246636 6th Mar 2014 2:20pm
found this in an old thread, any help?
RR Sidesteps Operation:
To force the steps to stay out regardless of the position of the doors, what LR call 'roof access and jacking mode' get in the vehicle and close the doors, quickly insert the key in the dash and turn to position two, whilst steps still out, then hold the switch for about five seconds until the light in the switch illuminates continuously then remove the key. The steps will now stay out regardless of the position of the doors unless you drive away or lock the vehicle at which point they will return to their normal function.
If the steps are working and you want to disable them: insert the key in the dash in position 1 and hold the switch whilst turning the key to position 2, the light in the switch will flash twice to confirm the system is now off. To turn the system on repeat the procedure but the light will now flash three times to confirm the system is now on.
Post #246639 6th Mar 2014 2:34pm
Thanks Stan, I already knew about how to lock them out, but I was hoping someone will have real life experience of this and be able to tell me if I've actually got to take the things off just so I can get my wheel balancing checked. Seems SUCH a faff! Discovery 4 HSE
Post #246640 6th Mar 2014 2:37pm
kungfupanda
United Kingdom 2014 Range Rover Vogue SE TDV6 Mariana Black
When I had my FFRR with deployable steps, I had the wheels changed at a garage. I told them I had the steps and they just used their high lift trolley jacks. Rather than go in from the side, they went in from the front or back of the vehicle and lifted it no problem.
Hope this helps.
Post #246650 6th Mar 2014 3:01pm
CSK
France 2013 Range Rover Autobiography 5.0 SC V8 Causeway Grey
My dealer said you have to leave one of the doors on the side you want to lift up the vehicle ajar. This prevents the side step from retracting. No problem to lift the car with the side step like this.
Post #246663 6th Mar 2014 4:13pm
JAYBOY
I would just lock them out. I can't see a problem after that. 2020 Porsche Panamera Turbo Hybrid (V FAST)
2018 JCW Mini Cooper
2018 Skoda VRS
Post #246764 6th Mar 2014 10:02pm
Adam, yes you are correct. The scissor jack would hit the step... Only problem is, after a couple of years the steps corrode on because no one uses grease anymore in this world!!!
Post #246768 6th Mar 2014 10:11pm
CSK
I've had the steps retracting when they were supposedly in the lock position. If the door is ajar, they won't retract.
Post #246794 7th Mar 2014 7:57am
When i lock them out to go on my 2 poster ramp, i not only lock them out but open the rear door's, click the latch over with a screwdriver and press the lock button (on the door card) down for safety... That way the rear door cannot be closed by accident.
If for some reason the car stays on the ramp for a long period of time, i would simply un-plug the two steps underneath...
Thumbs Up Thumbs Up Thumbs Up
Post #246801 7th Mar 2014 9:16am
Nomad
United Kingdom 2012 Range Rover Autobiography 5.0 SC V8 Zermatt Silver
I've jacked mine up with the steps locked out using a bottle jack in the jacking points. Not much room to work the jack handle up and down but it works fine. Thumbs Up 2012 5.0L S/C
Previous:
3.6 TDV8
4.4 HSE
P38 4.6 HSE
Classic 3.9
90 County
Series3 Lightweight
Post #246804 7th Mar 2014 9:31am
I think everyone is missing the original point... The op said the steps should be removed when using the scissor jack that comes with the car,,, Thumbs Up
Post #246806 7th Mar 2014 9:33am
i tend to jack mine up with a trolley jack in from the back or the front, if done this way you could leave the steps alone.. ... - .- -.
Post #246808 7th Mar 2014 9:45am
Stan, do you put the jack under the lower suspension arms rather than the official jacking points?
I did this once and it gets the wheel off the floor really quickly and easily, not all that jacking it 5 feet in the air malarkey. Discovery 4 HSE
Post #246825 7th Mar 2014 11:29am
yes mate.. Thumbs Up ... - .- -.
Post #246826 7th Mar 2014 11:33am
J evro
England 2008 Range Rover Vogue SE TDV8 Stornoway Grey
Anyone have a picture of the 'suspension arm' to place trolley jack?
Post #281996 20th Sep 2014 1:45pm
