![]() | Home > Technical (L322) > 12v Sockets / Cigarette Lighters not working |
nicedayforit Member Since: 11 Jun 2011 Location: Beside the Solway Posts: 3982 ![]() ![]() ![]() |
Are the two sockets that don't work only on when the ignition is on by any chance?
Discotigger Member Since: 12 Feb 2013 Location: Cumbria Posts: 804 ![]() ![]() ![]() |
Hmm, I've got a couple of questions, just so I've got everything clear in my head.
rej Member Since: 06 Jan 2014 Location: Stevenage Posts: 496 ![]() ![]() ![]() |
Yes the two that don't work used to only work with the ignition on (like the front one still does) Yes it is and early facelift model with tochscreeen There is a difference between knowing your sh!t and knowing you're sh!t 2005 Registered 2006 MY 4.4 AJV8 Range Rover Vogue Last edited by rej on 10th Mar 2014 8:56pm. Edited 1 time in total |
1. Front Cigar light IS working (charging my iPhone and radar detector) Socket in the boot IS working fine 2. Neither the socket in the centre cubby or the rear cigar lighter are working 3. I have a factory (I think) tow bar and twin electrics but nothing to connect to it so have no way to test if it works. Is it possible to swap the relays around as a test to see if it solves the problems and if so which ones or where can I get a replacement to try. I have a selection of relays for my E32 BMW 7 Series if any of these might work. There is a difference between knowing your sh!t and knowing you're sh!t 2005 Registered 2006 MY 4.4 AJV8 Range Rover Vogue |
The relay to look at is the Trailer Socket Relay (R252) according to the electrical manual, this has a switched connection to the two affected sockets. I'm not sure where that relay is situated, as the manuals don't give info on relay positions, type, number, etc. (typical LR!!). Wont be able to look in my girl till the morning, as it's pitch black outside now. |
This is the relay position in pre-touch screen cars, chances are it's the same one in your car.
Thanks, if mines looks like that I will try and swap 1 and 2 around tomorrow. If it works are relays dealer items or can I get anywhere. There is a difference between knowing your sh!t and knowing you're sh!t
Relays from any motor factor, just get one exactly the same. |
Just been out to my girl and had a look in the rear (mine's a touchscreen 05MY), the fuseboard and relays are different.
This is the rear fuse box on mine. Anyone know which one is for the 12v sockets in the centre. Manual says not to remove relays??
Rej,
Hi Rej,
Thanks I will try in the morning when it is light and hopefully might sort at minimal cost. Thanks for all your help do far. There is a difference between knowing your sh!t and knowing you're sh!t
No worries, we're all here to help. |
