![]() | Home > Maintenance & Mods (L322) > Adaptive/Cornering Lights & DRL Wiring |
n1cktdv8 Member Since: 19 Aug 2013 Location: Cheshire Posts: 1754 ![]() ![]() |
Ah.....mine dont work....but bulbs are there.....bulb check I think ! Is this where I put the car details and a bit about myself ?........ |
rej Member Since: 06 Jan 2014 Location: Stevenage Posts: 496 ![]() ![]() ![]() |
Mine had the bulbs in and look like they have worked at sometime as the surround has melted a little bit.
Vogue Member Since: 31 Jan 2008 Location: on the hill Posts: 3813 ![]() ![]() |
you need to check the power supply as there may not be one there - frequently headlamps are swopped s/h from other vehicles by previous owners which could explain why it looks like they have worked but don't |
It this just a case of sticking a circuit tester in the pins on the connector, if so how do I turn them on to get power to the connector.
