Home > In Car Electronics (L322) > rear camera on an 03 FF
Welshdragon
Wales 2003 Range Rover Vogue 4.4 V8 Monte Carlo Blue
For the ones who have done this mod on pre touch screen, Im thinking of fitting a rear view camera to the FF and just asking if all I need is these...
http://www.toysinyourcar.com/acatalog/rng_av_cam.html
http://www.ebay.co.uk/itm/290958436903?ru=...26_rdc%3D1
and a switch
I have loads of wiring and relays.
I had thought of having the cam on a switch so it could be used any time not just in reverse...and to be honest I don't need the cam every time I reverse the RR so really a switch would be better.
I HAVE seen the threads on rear cams pre 06 but all seem to work on reverse selected ( except Joe90's long thread Thumbs Up ) I was going to fit a switch like the PDC, DSC switches? so it looks standard on the dash.
Looks easy enough to fit. If it dont work.......burn it!
If the IId tool cant fix it.......burn the FF.
If the FF cant be fixed......buy a Land Cruiser!
If the LC cant be fixed..............................................BUY a horse !!
Post #249913 22nd Mar 2014 10:27pm
Welshdragon
Well looking into this more I'm scrapping the above idea, far to much time in comsuming and fiddly Laughing
I think going down the wi-fi camera route and using the smart phone as the monitor is far easier and far more versatile for the amount of cars we have to tow with. Thumbs Up If it dont work.......burn it!
Post #250039 23rd Mar 2014 5:21pm
Yes, technology is moving so fast there has to be a better way without all the wires. A battery powered IP camera might do it. Perhaps even a trip to the Spy Shop in London, they might have something suitable? If one could only get a good viewing position for a camera/s from inside the cabin..... .
Post #250160 24th Mar 2014 2:03am
most home IP cameras are 12 volt driven so Tims idea would work, or there are loads of wifi/BT cameras with dedicated mini monitors on ebay that will do the trick.. ... - .- -.
click link for ,
FORUM WIKI
HOW TO Ǝꓕ∀ꓕOꓤ PICS
Post #250169 24th Mar 2014 8:40am
Welshdragon
I saw these 2 and thought that's easier to wire up, even if you fit a cigarette plug and fit into the sockets in the rear of the ff or any of the cars we have its then not tide up to one car, you could even fit it to the rear of trailers with a bit of work.
http://www.ebay.co.uk/itm/WIFI-in-Car-Back...20e058beed
http://www.ebay.co.uk/itm/Wifi-in-Car-Back...485f8a1817 If it dont work.......burn it!
Post #250171 24th Mar 2014 9:22am
Very good Thumbs Up Wonder why the second one is only Android? Simply because of the app required to display the images? Got me thinking I could use my carpc as a wireless access point for displaying on front screen Smile .
Post #250217 24th Mar 2014 2:52pm
taskam
Scotland 2007 Range Rover Vogue SE TDV8 Java Black
Any idea why the second one has a connection to the brake light? 2007 TDV8 Vogue SE Java Black
Post #250315 24th Mar 2014 9:07pm
tsadpt
I fitted a camera years ago using the toysinyour car loom. Works well. I have yesterday fitted a cam to another car using a 2.4ghz transmitter, and it works amazingly well to her the signal from the bumper to the camera input....
Post #250381 25th Mar 2014 8:33am
jeffridj
United Kingdom 2003 Range Rover Vogue 4.4 V8 Alveston Red
The advantage of having it triggered by the reversing switch is that you dont have to do anything, it just works. You can still have a switch to put it on when not in reverse if you want. It's fun watching how much spray your throwing out the back on a rainy day Smile 2003 4.4 V8 Vogue
Added Tow Bar, Reversing Camera, Freeview box
Post #250392 25th Mar 2014 10:08am
ironhorse
United Kingdom 2003 Range Rover Vogue 4.4 V8 Giverny Green
used this when i fitted mine a few years ago,worked well with all the connections in the boot
the proper connectors with about 6" of wire are available from BMW for about £1.50 each that fit the plugs for the TV module
also fitted mine like on hear
http://www.rangerovers.net/forum/6-range-r...tes-3.html
Post #250405 25th Mar 2014 11:29am
T111RDY
Scotland 2002 Range Rover Vogue 4.4 V8 Java Black
I keep looking at these - especially as I've an E46 330ci Convertible aswell....
http://www.ebay.co.uk/itm/250904997448?ssP...1423.l2649 l:OolΞΞΞΞΞΞloO:l
2002 4.4 Vogue Java Black
Post #250428 25th Mar 2014 2:01pm
there are a lot of cheaper versions of that type that have number plate lights integrated.. ... - .- -.
click link for ,
FORUM WIKI
HOW TO Ǝꓕ∀ꓕOꓤ PICS
Post #250437 25th Mar 2014 2:36pm
ironhorse
not keen on the inter-grated number plate light ones=they give an uneven light patten on the rear plate (anal i know)
Post #250707 26th Mar 2014 10:36am
get two then and wire them through a multiplexer and get two images on the screen.. Thumbs Up ... - .- -.
click link for ,
FORUM WIKI
HOW TO Ǝꓕ∀ꓕOꓤ PICS
Post #250724 26th Mar 2014 11:37am
3D Thumbs Up .
Post #250730 26th Mar 2014 12:02pm
