![]() | Home > In Car Electronics (L322) > rear camera on an 03 FF |
Welshdragon Member Since: 20 Jan 2012 Location: here and there...but not where I should be Posts: 1901 ![]() ![]() ![]() |
For the ones who have done this mod on pre touch screen, Im thinking of fitting a rear view camera to the FF and just asking if all I need is these...
Joe90 Member Since: 29 Apr 2010 Location: Hampshire Posts: 6419 ![]() ![]() |
Yes, technology is moving so fast there has to be a better way without all the wires. A battery powered IP camera might do it. Perhaps even a trip to the Spy Shop in London, they might have something suitable? If one could only get a good viewing position for a camera/s from inside the cabin..... .
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35691 ![]() ![]() |
most home IP cameras are 12 volt driven so Tims idea would work, or there are loads of wifi/BT cameras with dedicated mini monitors on ebay that will do the trick.. ... - .- -.
I saw these 2 and thought that's easier to wire up, even if you fit a cigarette plug and fit into the sockets in the rear of the ff or any of the cars we have its then not tide up to one car, you could even fit it to the rear of trailers with a bit of work.
Very good |
taskam Member Since: 01 Apr 2011 Location: Shandon Posts: 121 ![]() ![]() ![]() |
Any idea why the second one has a connection to the brake light? 2007 TDV8 Vogue SE Java Black |
tsadpt Member Since: 09 Feb 2011 Location: West Sussex Posts: 176 ![]() ![]() ![]() |
I fitted a camera years ago using the toysinyour car loom. Works well. I have yesterday fitted a cam to another car using a 2.4ghz transmitter, and it works amazingly well to her the signal from the bumper to the camera input.... |
jeffridj Member Since: 27 Nov 2013 Location: Wales Posts: 29 ![]() ![]() ![]() |
The advantage of having it triggered by the reversing switch is that you dont have to do anything, it just works. You can still have a switch to put it on when not in reverse if you want. It's fun watching how much spray your throwing out the back on a rainy day |
ironhorse Member Since: 13 Dec 2013 Location: birmingham Posts: 355 ![]() ![]() ![]() |
used this when i fitted mine a few years ago,worked well with all the connections in the boot
T111RDY Member Since: 21 May 2012 Location: Dunbar Posts: 187 ![]() ![]() ![]() |
I keep looking at these - especially as I've an E46 330ci Convertible aswell....
there are a lot of cheaper versions of that type that have number plate lights integrated.. ... - .- -.
not keen on the inter-grated number plate light ones=they give an uneven light patten on the rear plate (anal i know) |
get two then and wire them through a multiplexer and get two images on the screen.. |
3D |
