Home > LPG > Moving LPG filler from towbar to bumper
Page 2 of 3 <123>
cliffy
2004 Range Rover Vogue 4.4 V8 Zambezi Silver
if ur removing the tow bar u could put the rear towing eye back on which conceals under neath it and a good location to weld onto or fabricate a bracket to that section
Post #250509 25th Mar 2014 5:30pm
steptoe
Knightrider wrote:
Hi guys I'm interested in the option of welding a plate under the car to attach the LPG filler as an alternative to having on the bumper. Makes sense as will avoid cutting holes into the car, any tips on exactly where I should or shouldn't have the filler plate welded?
Won't this mean kneeling down to fill up ? LPG pump nozzles aren't all the same and some can be a right faff to attach.
Post #250713 26th Mar 2014 9:51am
destructimo
United Kingdom 2004 Range Rover Vogue 4.4 V8 Epsom Green
I've got the detachable tow bar on mine and the installer welded an L-shape bracket to the n/s end with the filler attached to that and the hose is then protected from damage by the bracket and also sleeved in convoluted protection.
I haven't found filling a problem with a standard angled gasguard type pump. If you struggle you could always put it in off road height but I've not found that necessary.
Cheers
Clive
Post #250725 26th Mar 2014 10:46am
Rather than welding, if you remove the towbar bolts you could use one of the threaded bolt holes to fix a purpose made bracket securely.
Could be done so the fill point was discreet with most of the bracket never seen behind the offside reflector.
Post #250728 26th Mar 2014 10:57am
Sandyt
mzplcg wrote:
Actually. come to think of it, the P38's used to have them fitted in the 12S towing socket location so it might be possible to fabricate a suitable bracket for where the towing electrics go which is up behind the bumper.
One advantage of having it near the middle of the car is that you can go either side of the pump. Just a thought.
+1 I had it there on my p38 was a addle being able to fill up either side Thumbs Up
Post #250748 26th Mar 2014 2:00pm
mick-ne
England 2004 Range Rover Vogue 4.4 V8 Java Black
Hi heres where I put mine, you can barely see it from behind easy to fill from either side and its bolted through one of the existing holes in towbar mount.
Post #250832 26th Mar 2014 9:17pm
Googsy
I so badly want to paint that tow bar ... Whistle Present :2008 TDV8 HSE
Gone Audi A5 2.7TDI
Gone Discovery 3 HSE
Gone Mercedes CLK
Gone Range Rover 2.5 DSE
Post #250847 26th Mar 2014 10:17pm
mick-ne
Don't worry Googs its coming off and getting the treatment I will post a pic just for you Thumbs Up
Post #251019 27th Mar 2014 6:37pm
Knightrider
Hi guys just to give closure to this topic I finally got around to taking the towbar off and relocating the filling point. In the end I decided to attach a right angled bracket holding the filler to the solid plate that the towbar cross member was attached to.
The filler is now very discreet and this is a much a better option than cutting holes in bumpers so thanks to all of the tips and advice you guys offered. I've attached some pics of how it now looks - your thoughts are welcome.
 2004 Range Rover Vogue 4.4 v8 LPG, Java Black, 22' Hawke Alloys, Black Beast
Post #254626 15th Apr 2014 8:06pm
Knightrider
Is the filler safe where I have placed it? I could move it further away in the bolt hole closer to the bumper which would take it a few more inches away from the back box but would mean the filler was more noticeable from the back of the car? 2004 Range Rover Vogue 4.4 v8 LPG, Java Black, 22' Hawke Alloys, Black Beast
Post #254627 15th Apr 2014 8:11pm
Should be OK there, the filler pipe is connected to a non return valve in the tank, if it should get damaged then you will only get the small amount of gas inside the hose leaking.... Pete
Post #254646 15th Apr 2014 9:56pm
ebajema
Should be fine here.
But on LPG horror stories, I had big GMC Van with three tanks, 60 (original tank) and twice 120 liter (new tanks). All new filler hoses when the big tanks were installed. After filling them all up (linked together to the same filler) I noticed some leakage (drops of LPG) underneath.
SWMBO got a bit "upset" and insisted on calling the fire dept. Needless to say they went all out (must have been a quiet time for them Smile ) and the car ended up on a local abandoned Navy airfield for 4 days until it stopped leaking.
Took it to an LPG installer and it ended up being a dual fault.
1. the non return valve on the 60 liter tank (thank goodness not the 120 L tanks) was stuck in open position.
2. one of the new filler hoses had a badly clamped sleeve that allowed the gas to leak out (hoses less than a year old).
Note the filler was behind the license plate and the fire man underneath the car was trying to temporarily clamp the hose sleeve. Prior to this they measured the gas concentration, the leak was slow so no big issues. They still decided to tow it out and used the water to keep the LPG from evaporating too much Smile The tow truck driver was not a happy camper but drove anyway. Police escorted us to the airfield (we followed in my wifes little old Suz Swift Smile ).
Oh and having done some "dodgy" stuff with LPG and quite some work with hydraulics, make sure the connections are tightened properly and well and check for leaks afterwards Smile
 MY 2010 5.0 SC Galway green and sand interior!!
Post #254651 15th Apr 2014 10:38pm
Knightrider
Hi ejabama yeh we checked the filler pipe to filler joint after reconnecting with washing up liquid/water - no bubbles means tight as a virgin happy days 2004 Range Rover Vogue 4.4 v8 LPG, Java Black, 22' Hawke Alloys, Black Beast
Post #255215 20th Apr 2014 1:35am
klf400
mine is very discreet a bracket welded to the towbar armature out of sight but easily filled.
allthough the lpg regulations state the filler should be a certain height above ground level [ cant remember the height without checking but from memory its somthing like 450mm ] which would make the towbar fitments not high enough but who wants holes cut in the bodywork of their fatty !! Thumbs Up 1990 3.5 v8 defender
2000 4.6 v8 30th anniversary prins lpg
2004 4.4 v8 vogue prins lpg
2011 4.4 TDV8 Vogue
faultmate extreme
rsw allcoms
Autel 906BT
Gap iiD tool
Post #256149 25th Apr 2014 5:00pm
p38arover
Australia 2004 Range Rover Vogue 4.4 V8 Adriatic Blue
I wonder if one could fit an LPG filler in the petrol filler location like I had on my P38A (below). I haven't been outside to check the filler on the L322.
Our LPG systems use a screw-on ACME thread coupling.
 Ron B. VK2OTC
2004 L322 V8 Auto
2007 Yamaha XJR1300
Post #490100 27th Sep 2018 10:21am
Page 2 of 3 <123>
