![]() | Home > LPG > Moving LPG filler from towbar to bumper |
steptoe Member Since: 23 Jul 2012 Location: london Posts: 382 ![]() ![]() |
Won't this mean kneeling down to fill up ? LPG pump nozzles aren't all the same and some can be a right faff to attach. |
destructimo Member Since: 24 Apr 2013 Location: Kent Posts: 76 ![]() ![]() ![]() |
I've got the detachable tow bar on mine and the installer welded an L-shape bracket to the n/s end with the filler attached to that and the hose is then protected from damage by the bracket and also sleeved in convoluted protection.
nicedayforit Member Since: 11 Jun 2011 Location: Beside the Solway Posts: 3983 ![]() ![]() ![]() |
Rather than welding, if you remove the towbar bolts you could use one of the threaded bolt holes to fix a purpose made bracket securely.
Sandyt Member Since: 07 Nov 2013 Location: Wraysbury Windsor Posts: 2286 ![]() ![]() ![]() |
+1 I had it there on my p38 was a addle being able to fill up either side ![]() |
mick-ne Member Since: 30 Nov 2013 Location: durham Posts: 133 ![]() ![]() ![]() |
Hi heres where I put mine, you can barely see it from behind easy to fill from either side and its bolted through one of the existing holes in towbar mount.
I so badly want to paint that tow bar ... |
Don't worry Googs its coming off and getting the treatment I will post a pic just for you |
Knightrider Member Since: 22 Mar 2014 Location: England Posts: 125 ![]() ![]() ![]() |
Hi guys just to give closure to this topic I finally got around to taking the towbar off and relocating the filling point. In the end I decided to attach a right angled bracket holding the filler to the solid plate that the towbar cross member was attached to.
Is the filler safe where I have placed it? I could move it further away in the bolt hole closer to the bumper which would take it a few more inches away from the back box but would mean the filler was more noticeable from the back of the car? 2004 Range Rover Vogue 4.4 v8 LPG, Java Black, 22' Hawke Alloys, Black Beast |
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8797 ![]() ![]() ![]() |
Should be OK there, the filler pipe is connected to a non return valve in the tank, if it should get damaged then you will only get the small amount of gas inside the hose leaking.... Pete
Should be fine here.
Hi ejabama yeh we checked the filler pipe to filler joint after reconnecting with washing up liquid/water - no bubbles means tight as a virgin happy days 2004 Range Rover Vogue 4.4 v8 LPG, Java Black, 22' Hawke Alloys, Black Beast |
klf400 Member Since: 10 Sep 2011 Location: forest of dean Posts: 210 ![]() ![]() ![]() |
mine is very discreet a bracket welded to the towbar armature out of sight but easily filled.
p38arover Member Since: 16 Dec 2015 Location: Western Sydney Posts: 1583 ![]() ![]() |
I wonder if one could fit an LPG filler in the petrol filler location like I had on my P38A (below). I haven't been outside to check the filler on the L322.
