Home > Maintenance & Mods (L322) > Paint protection film
J90
France 2006 Range Rover Vogue Td6 Java Black
Can you use Paint protection film on the front and rear lamps to protect them from chips and scratches?
I cant imagine the rear lamps giving off that much heat so in theory the PPF would remain stable in constant use, however what about the front lamps? I would think extended use of main beam would generate too much heat for the PPF.
Does anyone have experience of it's use or opinions you want to share before I give it a go.
Ta, Travelling around in circles again.
Post #253330 8th Apr 2014 12:24pm
the headlights are pretty tough and i'd think you would be very unlucky to get stone chips on them but i suppose it does happen and there's bound to be some one selling a protective film of some kind.... ... - .- -.
Post #253332 8th Apr 2014 12:27pm
J90
I'm putting PPF on the bumpers and was toying with what to do with the left overs, hence the question. Travelling around in circles again.
Post #253333 8th Apr 2014 12:34pm
what about running the headlights for 30/40 minutes and see how warm/hot the lense is, this should give you an indication if the PPF will ok.. ... - .- -.
Post #253334 8th Apr 2014 12:40pm
TOF
United Kingdom 2006 Range Rover Supercharged 4.2 SC V8 Stornoway Grey
You should be fine if it is a decent quality film. The projector lens is set back a decent amount from the lens, so should be no problem.
Post #253399 8th Apr 2014 9:37pm
rej
England 2006 Range Rover Vogue 4.4 V8 Zambezi Silver
You can get film for covering head lights which is not that thick (helped someone put smoked film on his lights a while back) and no problems although they were halogen rather than xenon There is a difference between knowing your sh!t and knowing you're sh!t
2005 Registered 2006 MY 4.4 AJV8 Range Rover Vogue
Post #253412 8th Apr 2014 11:30pm
The headlamps will cope with film no problem... The heat from the bulbs is much less than the heat of the midday sun... Thumbs Up
Post #253418 8th Apr 2014 11:55pm
RR2008HSE
My FFRR came with film on the headlights. I didn't know it until an idiot in a Ford tried to make a new lane between me and a bus. Evil or Very Mad I came out of it with only very minor scratch to front bumper and light. Bumper removed and painted. Thumbs Up They removed and replaced the film on the affected headlight. Amazingly, it fully protected the light and I cannot recommend it more highly. I think it's 3M but I'm not sure as I wasn't the one to pit it on either time.
Post #253421 9th Apr 2014 1:44am
JAYBOY
Mines going in for the front bumper while I'm in Peru i think i'll get my lights done at the same time. Thumbs Up 2020 Porsche Panamera Turbo Hybrid (V FAST)
2018 JCW Mini Cooper
2018 Skoda VRS
Post #253607 9th Apr 2014 9:43pm
