![]() | Home > Maintenance & Mods (L322) > 2008 range rover tdv8 brembo discs and pads replacement cost |
Tim in Scotland Member Since: 25 Mar 2007 Location: Somewhere between here and there, if not then I'm all at sea or at home in Scotland Posts: 2181 ![]() ![]() |
Try GEMM at Larbert - they are non franchise Land Rover specialists.
specman Member Since: 20 May 2010 Location: Fife Posts: 250 ![]() ![]() ![]() |
To add to Tim's excellent list of info there is also Mike Aitken 4x4 near Ladybank in Fife 01337 831114
JMC Member Since: 01 Feb 2009 Location: Aberdeen-Angus Posts: 780 ![]() ![]() ![]() |
Before you go any further, what makes you think that you actually NEED to replace these items? Is it just because some stealer has quoted you for a job that you assume it is really needing done?
John, I agree with you on the "is it necessary front"! Over on RRS there are plenty of stories of guys with dealerships wanting to replace Brembo brake components unnecessarily - maybe mbdj should go for a second opinion. In three years of TDv8 RRS ownership I never needed any replacement Brembo components except a replacement rear disc which was done under warranty. 2018 Mini Countryman Cooper S E All4 PHEV in Melting Silver - it’s whisper quiet in EV and polluter modes |
I've done the pads on my 2009 TDV8 at 18k miles myself. Disks were perfectly fine but I suspect 'some' stealers would have automatically changed the discs, and charged a premium at the same time. |
mbdj Member Since: 14 Jul 2010 Location: scotland Posts: 98 ![]() ![]() ![]() |
thanks everyone for your quick reply's the discs have groves top and bottom but they work fine so i thought i would ask the local dealer for a price to change discs and pads front and rear going to phone around some of the names mentioned to see if it can be done cheaper thanks again. |
Mikey Member Since: 10 Jan 2008 Location: Dundee Posts: 1819 ![]() ![]() |
Strathearn Engineering ![]() Used them before, good bunch of guys, know their stuff |
ukrangie Member Since: 20 Jun 2009 Location: Kent Posts: 520 ![]() ![]() ![]() |
I just had my discs and pads replaced by Lookers at Bishops Stortford for £775 after an independent told me they needed to be replaced. The independent wanted £40 more for the same job. Thankfully I got through a 1800 mile drive around France before the brakes started to crunch. Paul
Like JMC says, if they need done then do them yourself. Basic tools and a trolley jack are all that's required.
The Flying Scot Member Since: 09 Apr 2009 Location: Surrey Posts: 77 ![]() ![]() ![]() |
Hi I've recently picked up a 57 plate TDV8 and the rear pads are seriously wearing thin.
alanm_3 Member Since: 19 Feb 2011 Location: my House, unless I’m not at home, in which case I’m somewhere else. Posts: 6781 ![]() ![]() ![]() |
It's a pretty straightforward job, assuming you have even a modicum of DIY skills! |
stagger Member Since: 05 Oct 2009 Location: Huddersfield West Yorkshire Posts: 72 ![]() ![]() |
I wonder if some people rush to change front discs, this one was on a vw van when the driver complained of the brakes squeeling. |
Ho Lee Fook!!!! |
Thanks Alan,
