Home > Maintenance & Mods (L322) > 2008 range rover tdv8 brembo discs and pads replacement cost
mbdj
hi just been quoted £750 to replace front and rear discs and pads with new sensors fronts are brembo anybody know any dealers near edinburgh/glasgow that could do this cheaper with original parts. Question
Post #25298 11th Aug 2010 8:23pm
Tim in Scotland
Location: Somewhere between here and there, if not then I'm all at sea or at home in Scotland
2010 Range Rover Vogue TDV8 Stornoway Grey
Try GEMM at Larbert - they are non franchise Land Rover specialists.
GEMM contact details are email - workshop@GEMM4x4.co.uk
phone - 01324 557735
Ask for George Maclay (owner) or Bobby Gunn
The workshop is at Railway Cottage, Larbert, FK5 3NN
With regard to other outlets you could ask over on the Scottish Land Rover Owners Club forum at http://www.slroc.co.uk/forum/index.php (they aren't averse to questions about modern landies there as many members have one in addition to an older Land Rover)
I have had lots of dealings with GEMM - they do all the repairs and maintenance on my Defender and I know they work on offroad racers and modern high performance Land Rovers Like Disco3/RRS and L322's.
There is another service outlet closer to you:
Alex Lindsay
* Address: Axwel House, Westerton Road, East Mains Industrial Estate, Broxburn, West Lothian, Scotland
* Telephone: 01506 854 827
However I have no experience of them and a search in google shows they do restoration and repairs.
There is another outlet BartTech in Airdrie too but again I have no experience, even further afield is highly regarded Strathearn or Strathnairn Engineering at Auchterarder 2018 Mini Countryman Cooper S E All4 PHEV in Melting Silver - it’s whisper quiet in EV and polluter modes
Post #25303 11th Aug 2010 8:49pm
specman
Scotland 2016 Range Rover Vogue SE SDV8 Aruba
To add to Tim's excellent list of info there is also Mike Aitken 4x4 near Ladybank in Fife 01337 831114
He is an independent Land Rover specialist and has done some work for me on my last Disco2 and my FFRR.
New twin electrics for my existing FFRR towbar was almost half the £300 main dealer quote.
Post #25309 11th Aug 2010 10:25pm
JMC
Scotland 2012 Range Rover Westminster TDV8 Orkney Grey
Before you go any further, what makes you think that you actually NEED to replace these items? Is it just because some stealer has quoted you for a job that you assume it is really needing done?
Brake pads are a relatively easy DIY job. Brake discs require a couple of more bolts to be released beyond doing the pads. It's not rocket science and, a lot of the time, it doesn't actually need to be done at all. Just be sure you're not being taken for a fool.
FWIW, I would probably manage to do all 4 corners with pads and discs in my driveway in about an hour.
Note that the genuine Brembo pads are not cheap (circa £130 for the fronts) but the rears are about a third of this (circa £40). There are new sensor wires in the boxes with the pads. I don't know how much the discs are but I'd suspect getting everything for about £300-350 tops! The older I get, the more I realise that people confuse wrinkles for wisdom Smile
Post #25335 12th Aug 2010 9:41am
Tim in Scotland
John, I agree with you on the "is it necessary front"! Over on RRS there are plenty of stories of guys with dealerships wanting to replace Brembo brake components unnecessarily - maybe mbdj should go for a second opinion. In three years of TDv8 RRS ownership I never needed any replacement Brembo components except a replacement rear disc which was done under warranty. 2018 Mini Countryman Cooper S E All4 PHEV in Melting Silver - it’s whisper quiet in EV and polluter modes
Post #25339 12th Aug 2010 9:49am
JMC
I've done the pads on my 2009 TDV8 at 18k miles myself. Disks were perfectly fine but I suspect 'some' stealers would have automatically changed the discs, and charged a premium at the same time. Rolling Eyes The older I get, the more I realise that people confuse wrinkles for wisdom Smile
Post #25346 12th Aug 2010 10:03am
mbdj
thanks everyone for your quick reply's the discs have groves top and bottom but they work fine so i thought i would ask the local dealer for a price to change discs and pads front and rear going to phone around some of the names mentioned to see if it can be done cheaper thanks again.
Post #25349 12th Aug 2010 11:34am
Mikey
Strathearn Engineering Thumbs Up
Used them before, good bunch of guys, know their stuff
Post #26124 21st Aug 2010 3:26pm
ukrangie
I just had my discs and pads replaced by Lookers at Bishops Stortford for £775 after an independent told me they needed to be replaced. The independent wanted £40 more for the same job. Thankfully I got through a 1800 mile drive around France before the brakes started to crunch. Paul
Twitter - Facebook
Post #27816 11th Sep 2010 7:47am
mzplcg
Like JMC says, if they need done then do them yourself. Basic tools and a trolley jack are all that's required.
Call Nick at Yeovil Land Rover for the parts. Sponsors over on D3 and proper prices to forum members. Mail order no problem either.
Last time I checked on my D3 (which are RRS Brembo parts) is was about 400 quid for all 4 corners, discs and pads with sensors and clips etc.
Unless you really are made of money I really wouldn't have a garage do this work. It's too easy to do yourself to throw away cash. Just think of it as 2 free tanks of fuel and an hour's work seems quite fair in deed.
Post #27818 11th Sep 2010 8:35am
The Flying Scot
Scotland 2012 Range Rover Westminster 4.4 V8 Fuji White
Hi I've recently picked up a 57 plate TDV8 and the rear pads are seriously wearing thin.
I've not approached the dealers yet for a quote but just popped into a local Kwik Fit as they offer a free brake check. They said they couldn't touch the rears due to the Electronic Hand brake which requires a special tool to release the caliper in order to get the pads out..
Is this correct?
I've changed the pads on my old TD6 RR without problems but didn't realise there was a special tool required for the TDV8.
Any advice would be greatly appreciated.
Tony 2011 Range Rover TDV8 4.4 Vogue SE
2007 Range Rover TDV8 Vogue (Sold)
2004 Range Rover Vogue TD6 (Sold)
Post #195171 19th Jun 2013 3:25pm
It's a pretty straightforward job, assuming you have even a modicum of DIY skills! Thumbs Up
I changed the rears a few weeks ago and saw no need for any special tools! Oh, and my parking brake still works! Whistle Got - 2017 SDV8 Autobiography in Loire Blue
Post #195174 19th Jun 2013 3:34pm
stagger
I wonder if some people rush to change front discs, this one was on a vw van when the driver complained of the brakes squeeling.
Post #195177 19th Jun 2013 3:44pm
Ho Lee Fook!!!! Shocked Got - 2017 SDV8 Autobiography in Loire Blue
Post #195178 19th Jun 2013 3:46pm
The Flying Scot
Thanks Alan,
I don't know what the Kwik Fit guys are talking about then regarding theis tool to release the Electronic Handbrake???
If it is as simple as the TD6 brake pad change then I will have a go myself.
Is there a Wiki on the process or is it as simple as
Jack car
Remove wheel
Remove caliper
remove old pads and sensor ( one side)
Instal new pads
Replace caliper
replace wheel
drive
Cheers
Post #195190 19th Jun 2013 5:00pm
